Question about Philips 14PT3685 14" TV
Cable isn't working on the TV
I have comcast cable and i screw in the cable cord into the back and i push ant/cable or whateveer the cable just wont work i've tried everything! how do i watch my cable on the tv?
  • 784 Answers
1-First to make sure that the cable cord has signal first by checking with a working TV in your house.
2-Need to set up your TV to receive CABLe or Antena in your TV menu set-up. However, you can see only analog channels . You won't be able to see digital channels unless you rent cable boxfrom Comcast. Good luck
Posted on Jul 15, 2009
Cable box now not working
Sounds like it is on the same circuit trying moving cable box to new plug use extision cord
Sep 03, 2014 | Comcast XFINITY
HDMI no longer working as pass through for Comcast and Tivo
sounds like your digital board is going bad. Is the unit still under warranty?
Jul 29, 2013 | Marantz Audio Players & Recorders
My TV is connected to cable. I want to connect a VCR to the TV....how?
You didn't give model numbers.... But for most equipment: hook the VCR to the TV's Yellow, White, and Red jacks using a composite video cord. Or if both have screw on Co-Axial type cords:
cable in to VCR's ANT IN, TV OUT to TV's IN.
Jul 03, 2011 | Televison & Video
I need help , hooking up my samsung HT-Z410 HOME THEATER, TO MY LG HDTV, SO THAT WHEN I'M WATCHING REGULAR TV THE SOUND OF THE TV CAN COME OUT TRUE THE HOME THEATER SPEAKERS, CAN IT BE DONE? CAN A COMCAST...
first of all here is a link to the manual....http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf and yes it can be conected thru your comcast but you wil need to buy probably cheapest at wallmart an RF Modulator (Less than 20 dollars) and from your cable box (vidieo out, or to tv) install the cable to the rf mod unit (ant in) and that converts it from coaxial cable to rca (meaning a cord with yellow ,red,white push on connectors) plug the red and white into aux input on surround system (see #3 on manual view on backside of surround unit)and and you got it.It your tv does not have a yellow vidieo connection (which is where the the yellow plug into tv)in the back then add a coaxial splitter after the comcast box so that the 1 coax line goes to tv and the other coax goes to the rf mod then thru RCA cables to the surround sound.you may need to buy xtra cables but they are cheap. hope i helped........you may try asking family or friends for the above equipment i described.the newer tv's dont need it and many people have this stuff layen around...good look
Jan 18, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
I have a comcast digital converter box and i need the manual to hook it up to a tv
Here is the easiest way...
1. Connect coax cable from the wall to the "Cable in" on the cable box.
2. Connect a coax cable from the back of the TV to the "To TV" output on the back of the cable box.
3. Tune your TV to channel 3
4. Plug the power cord into the back of the cable box and into a power outlet.
5. If you do not have a picture call Comcast and ask them to send a signal to activate your new box.
6. Enjoy your new programming.....
Good Luck...
Jan 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to connect tv to comcast cable box
If you only have the comcast receiver and a TV, take the input (wire from outside the house or outlet on wall) and screw that onto the input of the comcast receiver. Take another wire (or RCA, component connecters or whatever means the box and TV provides) and go from the output of comcast receiver to the input of the TV. Set the TV input mode (on the TV itself or by the remote) to whatever mode you hooked up the cables to (video 1, aux, video 2, etc) and you should see a picture. From there use the comcast remote to change channel. If you use the round cable (rg56 or rg59) you will not need any other connections between the TV and the box. The video and audio are broadcast on the same line. If you use RCA (yellow red white) connectors, yellow is video, white and red are audio) you will need all three wires from comcast receiver to TV. I hope this helps and good luck!
Nov 18, 2009 | Audio Players & Recorders
RCA DRC8030N
That sounds about right if you have cable instead of an antenna cable. If it can't tune anything but 5 channels in, that's all it claims; set it to CABLE IN instead and try that so the tuner can get along with your cable box. If you really do have an antenna hooked up, get it away from whatever's reflecting signal and screwing up reception.
Sep 12, 2008 | RCA DRC8030N
Ant/cable
your box might be blown out
also call the cable company to see if the outage didnt affect them
they might be out too
on the TV you might to look for setup or init setup
a model number of the tv set wouldnt hurt too
Jan 06, 2008 | Curtis-Mathis CM19011 TV
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Philips 14PT3685 14" TV Logo
195 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
