Question about Akai LCT3285TA 32 in. LCD Television
Need to turn on closed captions Akai 37
Need to turn on closed captions Akai 37" lcd
kc02a2
    President:
  • Akai Master
  • 1,779 Answers
Go into the Menu under audio and navigate to CC and turn it on to Text 1.
Posted on Jul 15, 2009
HOW TO CLOSE SUBTITLES ON LG 37
Keep in mind if using a box it also likely has closed captions feature.
In both set and or box in the menu find Captions--turn off or to one of the other options except TEXT---most sets use CC1 as default and some also offer captions when sound is muted or not.
Look first on remote for captions, usually someone hits the button by mistake either for the box or the set--you may have to check both units to find it.
Apr 02, 2012 | LG 37LG30 37 in. LCD HDTV
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Above pretty much says it. The "Caption" function under "Option" is greyed out. Can someone tell me how to "ungrey/activate the closed caption option?
If the closed caption is shaded out in the menu, this usually means closed caption is not an option. Closed caption can not be turned on if the TV is on component, RGB, DVI, Or HDMI inputs. The closed caption will need to be turned on by using the set-top box or other device that is connected to TV inputs. or if the tv is connected directly to the cable line or anteanna
Dec 03, 2010 | LG 37LP1D 37 in. LCD Television
How do i shut off the closed caption ?
Hi, if you have the original remote control unit, look for the key denominated "cc" close caption and press it once at a time until the caption indicates "off".
Nov 29, 2010 | Protron PLTV-37 37 in. LCD Television
Closed caption is on how do you turn it off
Ur tv romote have a button CC.Push the remote button to turn off CC 1,2,3.Close Captionning should shut off.
Aug 05, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
I can't turn the closed captioning OFF on my insgnia flat screen tv model NS-L CD37. i have a universal rca remote & the closed captioning won't go away - HELP !
The problem is that the universal remote is not sending the correct IR signal to your units IR receiver, regaurdless whether or not you turned the captions on with the universal, it is unable to send the signal to turn them off, if you have a menu button on your unit you could try accessing the closed caption option that way, alternatively you can do a system reset, if you can access that menu option, you may need to do a tv retune to get your stations, but the closed captioning should be off. I hope this helps. Good luck.
Jun 07, 2010 | Insignia 37" LCD Flat-Panel HDTV
Can't turn off closed captioning
CC is either active on the Cable Box or the TV, check your settings on both.
Jul 08, 2009 | LG 37LP1D 37 in. LCD Television
We can not get CC Closed Captioning to turn off.
had a power outage and it said to reset the clock I went some where and changed the close caption from off to on. It was a in a set up menu
Jun 09, 2009 | LG 37LP1D 37 in. LCD Television
How to remove closed captioning
On the TV's user menu (press "menu" button) look for "Captioning" or "Closed Caption" choice. If not immediately in view look in "set up" or "Audio"...it should be in the menu. Find it and then turn it off.
Apr 07, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
Closed Caption Option
CHeck on the comcast box- you may have to turn off (POWER) then click (SELECT)select button to get into the user interface , there you may see that closed catptioning is off, turn it on and it should work.
Mar 07, 2008 | LG 37LP1D 37 in. LCD Television
Akai LCT3285TA 32 in. LCD Television Logo
119 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
