DVD player won't turn on after power outage
I have a JVC TH-C3 DVD player and after a power outage it will not turn on....it was plugged into a power bar with other things which all turned back on, but the DVD player has no power at all....I checked the power fuse inside the player and it looks good....what else can I do?
    Scholar:
  • 113 Answers
Hiya, sorry to say that the power supply is probably damaged, sometimes happens with power outs. Unless it is expensive model, they are sometimes not worth fixing (although the fault could be very simple like a single diode etc. Maybe send it in and ask for a quote, then decide if it is worth it.
Best of luck
Posted on Jul 15, 2009
  • purrmiau-123 Mar 02, 2011
    Exactly the same thing happened to my Panasonic DVD recorder, everything else in the power strip would turn on, except the recorder. I've had it for a few years, so I don't think it'll be worth repairing it. Next power out I'll turn the strip off before power comes back.
I have a RCA rcr6473n And would like the codes to set my JVC dvd digital theater system th-c3 5 disc player
Check codes in user's manual:
http://www.rcaaudiovideo.com/docs/common/RCR6473N/RCR6473N_OM.pdf
If can't find a code, folloos the procedure to scan codes for your remote to get an unknown code
Oct 18, 2015 | RCA Audio Players & Recorders
My jvc dvd player xv-thc50 won't turn on
if your dvd player has no any power indicator at the front, the first place to be checked will be the power supply. look for a blown fuse bad component parts like shorted diode and an open resistance.
Oct 15, 2012 | JVC Televison & Video
I can not open my dvd player on my jvc th 555
You may try pulling the power cord out and leave it out for about 10 minutes then plug it back in. Sometimes it resets the circuitry and allows you to used the eject switch. I have been succesful in the past with a DVD player I own.
Aug 09, 2011 | JVC Televison & Video
Jvc th-s3 won't turn on...blue light flashes briefly and then goes out
from my experience, I think your player is having a power problem. It must have received excess voltage/irregular power supply which has damaged an IC or capacitor on the power board of the player.
Sometimes this excess power supply might damage the player's main board. This is why it is advice able that you use step down for your player, because DVD player don't need excess power as something might be damaged.
To solve this problem, you will be needing a meter. Open the player, use the meter to read the components on the power board as it will help you discover the component that got damaged and you can then replace the bad component.
But if you do not have the knowledge of fixing this problem, you might be needing the help of a service technician.
Take care.
May 13, 2010 | JVC TH-S3 System
Listen to DTV DVR output on TH-C3
im not familiar with this model. can i assume it is a small home theatre system with limited inputs?
in that case, the best thing to do is to feed all your devices...cable, dvr, dvd, etc....into the tv.(audio and video). then use the audio output of the tv to the input on the receiver. you may have to go into the tv menu and set the audio output to the speakers in the tv to fixed mode for a constant level out to the receiver.
good luck
Dec 08, 2009 | JVC TH-C3 System
Our power went out briefly and now the DVD player won't turn on
Hello sir/ma'am, my guess is that the dvd player's power supply fuse gave in. Im not familiar with your dvd player, if you can open the dvd player and locate the check the fuse. replace it if its blown up. hope this helps. if you may have any more inquiry feel free to ask me again. best regards, thanks.
Jul 15, 2009 | JVC TH-C3 System
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
I have a JVC TH-M505 home theater system and when I plug everything together and turn the power on the main unit and begin to play a cd/dvd etc...I cannot get the sub unit to power up (the light does not...
you may want to re check all your connections.
are you plgged into a power bar or directly into a wall socket.
also you may have a defective power supply on the system . you can also check this website out it is free to join and you can download manuals and get help
http://audio.manualsonline.com/manuals/mfg/jvc/jvc_th_thm505.html
Apr 26, 2009 | JVC TH-M505 System
Jvc dvd player
press and hold stop button more than 5 sec and ur player will be unlock
Nov 08, 2008 | JVC XV-N320 DVD Player
1,121 people viewed this question
 Grubhead
Grubhead
