Question about Nokia 6600 slide Cellular Phone
My Nokia 6600 slide screen suddenly went blank then two days after the earpiece stop outputting sound. I have to be using the speaker phone. Two problems occur one then the other, the screen went blank then the earpiece stop sending out sound
  • marlon_2005_ Jul 15, 2009
    I found the solution to be very helpful, I already ordered the screen which is on its way, now I am going to order the belt otherwise known as the flex cable.
  • 4,924 Answers
Ok...this is just the beginning ...this means that the band that makes the connection between the 2 halfs ..its starting to damage itself in a side...first ..you lost the display ....then the earpiece ......and next you will loose what ever functions depends on this band that makes the conection from the body ..to the displey side......this band ...( its more like a ide cable into a pc ...but miniatural ..) it will keep demaging cause its the only mobile cable into that phone.....it is kinda rolling like a folded in 2 paper...when the phone slides... and each time you open it ...you keep damageing this ...the solution is to replace it ...there are available in most phone stores..it should cost about 20 E ...but if this model has it glued on the display ...it will cost more cause you have to buy them both ...the tape-band conector ..and displey ... I will look for this model on the internet ...and leave yoiu a comment with a link for you to make an idea ...
Posted on Jul 15, 2009
I've a peavey vypyr 75 amp I used it with the headphones, few days ago it stops the output to the speaker, but it works if it's auxiliary input means the speaker is OK. From the jack input to the...
Phone output jack connector, this kind of connector acts as a switch that when you have your earpieces connected the speaker is automatically disconnected, and when you unplug your earpiece then the speaker activates, so there's your issue.
Oct 01, 2013 | Peavey Audio Players & Recorders
My Nokia 5230's volume suddenly went very low. Either I've made a call or receive a call, the volume when answering the phone is very low. I've increased the handset volume to maximum but it's still low....
Please see if there is dirt clogging on the earpiece that would have reduced the volume from the speaker. If so use a pin and soft cotton to clean or you must open the cover and use a brush and air jet.
Secondly the possible weakness of the speaker/earpiece or the weakness of the low power output amplifier is another possibility.
Feb 18, 2011 | Nokia 5230 Cell Phone
LG ls670 optimus S - phone 5 days old - used speakerphone and it suddenly stopped working - now I have NO speaker for phone or media or ring feature - vibrate still works, though. All basic settings have...
My phone is 3 months old. I can not here the caller unless I have my earpiece in or I have it on speaker. They sound really far away Anyway to resolve this issue other then getting a new phone. Thanks in advance.
Dec 31, 2010 | LG Cell Phones
I cant hear anything on my nokia 6500s expect on speaker
The problem with your phone is the earpiece, since you have adjusted and try increase the volume, yet, same problem. The earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Replace the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Aug 09, 2010 | Nokia 6500 Slide Cellular Phone
Cannot hear anything on receiving call bt able to hear with speaker on or on hand set......
you have to change your speaker (earpiece)
when you choose the loud speaker option,,
you will able to hear the voice,,why?because the sounds transfer from earpiece to buzzer..its same when you use headset..the sound from earpiece will transfer to headset speakers..in that case,,you need to replace your earpiece..100% your problem will be solve!!
Jun 16, 2010 | Nokia 3110 Cellular Phone
Screen is completely blank, cant access anything.
Good day sir/ma'am, the problem with your phone sound can be that the driver speaker(earpiece) is defective or it may opened wiring/unsoldered to the driver. also check the volume or mute. 2. the display problem may be caused by intermittent contact problem or the display lcd is lose. you may have to dismantle it and look for these things and fix it. Hate to say it but you may need to bring it to a cellphone technician. Hope this may help. thanks
Jul 16, 2009 | Nokia e65 Cellular Phone
Incoming call sound
that not possible becouse 6600 have monophonic speaker so output not increase or u can use .wav files to get increased volume.
Jul 11, 2008 | Nokia 6600
Earpiece volume
Your earpiece might have a problem. Normally the volume on the phone works with the earpiece
Jan 11, 2008 | Nokia 6600
Nokia 6600
maybe the lcd connector was off.takoff the front cover and screws and try to conect it again
Sep 06, 2007 | Nokia 6600
Nokia 6600 Volume Problem
Low handset volume during conversation? or volume in ringing tones, if during conversation press the right arrow key you might hear the changes, increasing volume, if still, need to bring it to service personel for earpiece replacement.
May 14, 2007 | Nokia 6600
Nokia 6600 slide Cellular Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
