Question about Refrigerators
Ice maker was full I removed the ice container and when I replaced it the ice maker failed to make ice.
  • 21 Answers
CHECK CUT OFF ARM.TRY PUSHING DOWN TO TURN ON
Posted on Jul 15, 2009
I have a GE refrigerator, model TPX24BPDA, that has an ice maker that won't stop making ice! Whatever mechanism that senses when the hopper is full isn't working. I can't locate any sensor either.
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Oct 05, 2016 | GE Refrigerators
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
The ice door will not open like it used to. Now I have to reach in with my fingers to open it to get ice through the door.
Good Morning Misty, thank you for your post!
It is a good idea to clean the ice dispenser and ice container if the ice dispenser sticks or before contacting an experiencing technician to assist further.
1. First, stop ice production by lifting the wire signal arm to the "up" or OFF position (side-mounted) or the ice maker's On/Off power switch turned Off-set to the "O" position (rear-mounted).
2. Remove ice container by lifting up and out. Empty and carefully clean the container with mild detergent. Rinse with clear water. Do not use harsh or abrasive cleaners. Allow ice container to dry completely before replacing in the freezer.
3. Remove ice chips and clean the shelf and chute that supports the ice container.
4. Replace the ice container. Lower the wire signal arm on the ice maker to the "down" or ON position (side-mounted) or the ice maker's On/Off power switch is turned On-set to the "I" position. (rear-mounted) and the ice maker will resume production.
I hope these troubleshooting tips help you in some small way.
Sep 24, 2013 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
I lost the instructions for the Baskin Robins ice cream maker. Are there some available online?
General Ice Cream Maker Instructions... This should give you the general idea on how to use any ice cream maker. Typically, the ice cream straight out of the maker will be soft so the ice cream typically goes into the freezer to "set"/harden the ice cream.
The ice cream maker should have a container inside of the larger outer container. The ice cream mixture goes into the inner container and the outer container holds the ice-salt mixture.
1. Prepare your ice cream mixture and chill.
2. Pour the chilled mixture into the inner container about 3/4 fulls.
3. Insert the Mixing paddle and cover the inner container
4. Turn on motor and while it's running, add 2 inches of ice on the bottom of the bucket. Sprinkle about 1/4 cup salt over ice. Continue layering ice and salt until the ice level reaches the top of the rotating ice cream can.
5. As the ice cream maker runs, add more ice and salt to ensure the ice level is above the mixture level in the inner container.
6. In about 20 to 40 minutes, the ice cream maker should stop churning.
7. Remove the lid and pack down ice cream in the can.
8. Cover and place ice cream can in freezer for several hours to harden. http://www.epinions.com/review/Baskin_Robbins_Ice_Cream_Maker/content_25404149380 The instructions are on the "mix" packs, all you need is the half & half, rock salt and a freezer. Freeze the canister, insert the canister into the receiver, add the mix and the half & half (on the pack), cap it add the ice around the canister, add the salt over the ice, turn on the machine and stand back.
May 05, 2011 | Toys
The ice maker will not shut off on the LG refrigerator.
the internal switch that is supposed to shut the ice maker production off when the bucket is full has failed. Replace your ice maker
May 07, 2010 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker leaks water into holding container, frezzes up holdeing container, ice wont despence , because its froze
sounds like your ice maker has a degraded coating on the mold that forms the cubes. if you remove it from the freezer, then you can see if the coating is coming off. if so then you need to replace the ice maker.
Jan 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
KitchenAid KSRG25FKSS16 Side by Side will not make ice
First I would check for obstructions in the line from the water inlet valve to the tray assembly. If thats good check the valve it self. This is a double valve, it supplies water to the door and it supplies water to the ice maker. Check and compare both coils. They should be around 300 Ohms. If not, replace it. Try Partselect.com
Oct 10, 2009 | KitchenAid Refrigerators
Ice maker leak
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Aug 19, 2017 | Electrolux Frigidaire Professional Series...
Ice Dispenser
If you access the ice container and remove any partially melted ice - maybe the ice maker will work. We had a similar problem. We opened the ice reservoir and discovered ice cubes that had partially melted together. Once we removed those, the ice maker and water dispenser returned to normal. Now we check every so often.
Apr 04, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
