Question about Kitchen Ranges
I was baking , the first cake came out perfect. The second cake started to burn, the element did not turn down in heat. The oven red light stayed on.
  • 3,037 Answers
Most likely the problem is a bad control board. Happens once in a while to ovens, usually GE ovens. You need to replace the board. I can look up the part number and a place to order it if you give me that make and model number of the unit. Otherwise you can order one from the manufacturer or go through the place that you bought it at.
Benjamin
Posted on Jul 15, 2009
I have FGES3065KFA gallery and I have baking problems. It bakes outside of the cake but inside of the cake stays raw. Me and my husband check the bake and broil element they work fine. We change the...
read the mixture instructions
try preheating the oven for the required temperature or when the thermostat turns the light off
insert the cake to be cooked and leave it there for the desired time
Too hot will burn the outside with out cooking all the way through
check the ingredients carefully as if the mixture is too wet ( butter, milk, water all make it wetter than required )
Place the cake in the center of the oven ( not on the bottom shelf or the top shelf)
All these may sound mundane but they all point to getting a good cake result
Sep 14, 2015 | Frigidaire FGES3065KF Gallery 30" Slide In...
Suddenly burned cakes
Could be temperature control failure
May 25, 2017 | Smeg Ovens
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
Whirlpool Self Cleaning Oven - Model RF360BXXW Serial # FA4005915 Turned oven on bake - bottom element is not heating however top element is. Tried to change setting to 'timed bake', 'broil' and 'clean'...
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I am using an old white westinghouse electric oven to bake a cake. I selected the right temperature which was between 150 and 160 cel. It started but I could hear the sound of a fan. I kept it on for at...
Either the temperature sensor has a problem (shorted so the control thinks the oven is colder than the actual temp) or a relay feeding the bake or broil element is welded shut and causing one of the elements to stay on. If the elements are still heating when the "ON" indicator is NOT lit, then you have a welded relay. You need the control board repaired.
Jun 25, 2010 | Philips Ovens
HEATS UP BUT TAKES 2 TIMES LONGER TO BAKE, tried cookies and cake, had to keep putting back in for longer. Did not burn, but had a weird consistency. Looked at baking coil, 'looks' fine and does get...
your bake element should get red during the preheat time and also if you leave the door open after it has preheated.
if it is not that will cause your oven to not heat right.
even if it looks ok, it could still be bad.
unplug the oven and remove the bake element, then take it to your local parts house and they can check it for you.
this is the most common problem, but it could be a problem with your oven control. try the element first.
Jan 09, 2010 | Amana ACF4225AS Electric Kitchen Range
Oven not heating up light ok fan ok
hi Lorraine. Thanks for choosing fixya! Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Nov 05, 2009 | Creda C361E Electric Kitchen Range
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
