Bad water pump on my washing machine
I was advised that my water pump on my washer was bad/leaking. This confirmed my suspicions - unfortunately.
Can anyone lead me down the road to replacing it myself, i.e. online manual or simple instructions?
Also, how do I determine which water pump I need to buy for replacement? My washer is a Kirkland Signature Washer made by whirlpool if that helps - pretty basic unit. I have had it for 5-6 yrears now.
Thanks to Montgomeree for previous advice.
  • 5,911 Answers
Is this a top loader? If so, these instructions should work for you since this is a Whirpool manufactured washer:
http://www.fixya.com/support/r397094-replacing_water_pump
Replacement pumps can be purchased on line at searspartsdirect.com or appliancepartspros.com. Both sites offer excellent illustrations and competitive prices, so shop both for the best price. The pump is listed under the heading for the Pump/Motor/Gearcase. Just use the model number off your washer for your search criteria.
This is a fairly simple repair, but if you have questions along the way, please let me know. I hope this helps you.
PS If my instructions aren't accurate, or if this is not a top loader, please post back with your model number so that I may be able to determine how your washer is contructed.
Posted on Jul 15, 2009
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaking water. The hose is draining correctly. Not plugged up
you may either have a leaking drain hose or bad water pump. these washers are famous for drain pumps leaking. this is caused by using to much soap. 2 tablespoons per load.
Jun 03, 2011 | Kenmore 24032\24036 Top Load Washer
Machine pumps out water but will not spin
There is a chance that the lid switch is bad but more than likely you have a bad motor. Unfortunately, GE placed a motor with a computer board in their newer washing machines and it is prohibitively expensive to replace.
Feb 18, 2011 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Washer leaks water from bottom of machine, a lot of water !
sound like a problem at the washer pump at the bottom of the washer. could be a loose hose or bad seals on pump.
Dec 17, 2010 | Washing Machines
My washing machine leaks when it's does the washing cycle
if the leak is at the frount of washer than you have a bad seal in water pump.you will nead to replace the pump.
Jan 17, 2010 | Kenmore 22422 Top Load Washer
We have a Whirlpool,Type 111
you have a bad drain pump
May 18, 2009 | Washing Machines
I have a problem with my washing machine..
Basic Washer Problems
No fill:
Bad water valve
kinked hoses
unpaid water bill faulty electronics. Overfill:
trash in water level switch tube
bad water valve
bad water level switch faulty electronics. Washes but don't spin:
bad lid switch
bad drive coupling or belt
bad motor faulty electronics Spins pumps but don't wash:
bad timer
bad motor
bad luck faulty electronics. Leaks:
bad hoses
bad pump
bad tub gasket faulty electronics. Fills washes but never advances:
bad lid switch
locked up pump
bad motor
bad timer faulty electronics. Goes through complete cycle but clothes soaking wet:
bad belt
bad pump
bad thrust bearing faulty electronics*. *electronics in appliances ****. My opinion.
Dec 28, 2008 | Washing Machines
Water leaks and spin cycle not working properly
Water leaking from the bottom usually indicates either a bad hose , bad hose connection to the pump or a leaking pump. Also sounds like the machine is not spinning out. Is there water left in the tub at the end of the cycle?
Feb 28, 2008 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
953 people viewed this question
Top Washing Machines Experts
