Question about Plumbing
Well-Rite WR240R makes loud noise every time water flows into it
Well-Rite WR240R (well pressure tank) makes loud noise every time water flows into it-
  • nimt Jul 16, 2009
    Hello ?mrrevol?.
    Every time the contacts are made to turn on the well pump (to pump water into the Well-Rite holding tank), the noise comes from the tank itself ? is hard to describe, but sounds almost like a groaning sound, crescendos up, then back down, lasts about 2 seconds ? very loud. It?s almost like a very loud breathing (very loud), or like a big balloon that air's being let out, or (sorry for this one) like someone's passing gas . . . real loud.
  • Bill Johnson May 11, 2010
    what kind of noise bang or running water?
    Genius:
  • 1,114 Answers
Tank may be air bound. There is an air valve on top of tank. Take cap off and depress valve momentarily. If water comes out of valve, the bladder is torn, and new tank is needed. If no water comes out, check the pre -charge pressure of tank.
First, run water in house and take note of the on-off pressure of your pump. There should be a water pressure gauge on the water line going into the tank. Take note of the cut on pressure and cut off pressure. Most well systems typically operate at 20-40, 30-50 lbs of pressure. Next,shut off electric to pump. Drain all water from tank. Take a tire gauge and check air pressure of tank. The static or pre-charge pressure should be two lbs less than the cut-on pressure,i.e if your system operates at 30-50, then the pre-charge pressure should be at 28lbs. Adjust pressure as needed. A small air compressor is ideal to use if more pressure is needed.
Posted on Aug 16, 2009
How do I plumb in a wr240r tank
Posted on Jul 13, 2011
My water heater makes a loud bubbling sound for a few minutes after I run hot water for a while. Is there something I should do for this? If so, what and how? Thanks.
The horrible noise you hear when the water heater fires up is probably caused by mineral buildup in the bottom of the tank. Hot water rises and flows by convection to the top of the tank. When you take a shower or turn on the dishwasher, the hot water you use is replaced by cold water that migrates to the bottom of the tank to be heated.
As far as the fix, regular maintenance is the key. The best thing a homeowner can do is to flush the water heater on a monthly basis. This simple process involves hooking up a garden hose to the drain valve at the base of the heater, opening the valve and with the water inlet valve open to maintain the pressure in the tank, allowing the water to flow until the water runs clean. Try this first. It may help. If not, de-liming is the other option.
Mar 02, 2015 | Water Water Heaters
How do I stop the loud noise when any of the hot taps are used?
I take it your water pressure is high. If so, then you need to have this pressure reducer installed because the water valves in the machine open and shut instantly, which means it lets too much water at once and when the valve closes or opens it makes a vibrating noise. See if you can check how fast the water is flowing at the tap first. Most washing machines make some noise one way or another, be it from tub spinning to rattling and clanking or water flowing in the tub, etc. From your description, sounds like you have a high pressure pipelines in your house, a reducer is necessary. Alternatively, try and turn down the mains tap at the front of your house, where the meter is, so that less water pressure rushes inside the house pipelines. I did that and it's a little quieter.
Jan 29, 2015 | Washing Machines
Max e therm heater makes loud noise at start up and does not stay on? What could it be?
Water flow might be the issue. Check the Thermal Reg or any other external by-pass.
Jul 24, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Bought a used Tassimo, is it supposed to make loud noise when brewing?
The water tank is probably not seated correctly.It can look as though it is, but you have to make sure the forward edge of it has been tilted so that the angled indentation in the plastic exactly mates with the machine.If it doesn't, water is not drawn from the tank, the pump makes a noise, and steam comes from the pod area.
Sep 24, 2011 | Braun Tassimo Espresso Machine/Coffee...
I have a starite propane heater i turn it on it calls for heat it will start heating then a couple minutes later the filtration lines and heater give a loud banging noise and service heater light comes on...
This is either one of two thing.
Either you pump is clogged, or failing and not providing adequate flow, or the heat exchanger has a hole in it. I would hope that it is just a flow issue as the exchangers are very expensive.
Check the pump first, and also make sure there is no leaking water from the heater
Nov 14, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Carver cascade 2 No water at all comes out of the hot water outlet. The inlet non return valve has been changed & is working correctly.
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Oct 06, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
High pressure, and heater noise
I am not sure if you have solved this issue, or not, but if the PSI on the gauge is high then the problem may not be the heater. When you have the system turned on, and the PSI is reading higher than normal, just the flow of water coming out your return lines. If the flow is normal, like when you clean your filter, then see if you have a way to re-route the water so it bypasses the heater. If the PSI on gauge drops, then the issue is in the heater.
If the flow of water is slower than normal, with the PSI reading high, then you have a blockage somewhere in the system. It could be something simple like removing debris from skimmer and pump backets, to time to backwash, or clean, the filter.
If the flow of water is really hard and fast, with the PSI high as well, then you have too much water going through the system and need to slow it down.
Jun 27, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Plumbing Logo
2,414 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
