Question about Plumbing
Makes loud noise every time water flows into it
  • nimt Jul 16, 2009
    It?s the blue tank
  • Bill Johnson May 11, 2010
    is the tank blue or silver?
  • 523 Answers
If the water is a banging type noise in your piping this would be water hammer the sudden stop of water within the piping. If the pump is making heavy noise (like it is pumping gravel) this is typically due to lack of NPSH (suction condition) If this is the case you may be lifting the water too high (suction lift) or the pump is trying to pump too much. In this case throttle a valve on the dischage side of the pump to help bring it back in to an are where as there is enough NPSH (Net Positive Suction Head)
I hope this may have helped,
Tom
Posted on Sep 25, 2009
2 Suggested Answers
  • 1114 Answers
SOURCE: Well-Rite WR240R makes loud noise every time water flows into it
Tank may be air bound. There is an air valve on top of tank. Take cap off and depress valve momentarily. If water comes out of valve, the bladder is torn, and new tank is needed. If no water comes out, check the pre -charge pressure of tank.
First, run water in house and take note of the on-off pressure of your pump. There should be a water pressure gauge on the water line going into the tank. Take note of the cut on pressure and cut off pressure. Most well systems typically operate at 20-40, 30-50 lbs of pressure. Next,shut off electric to pump. Drain all water from tank. Take a tire gauge and check air pressure of tank. The static or pre-charge pressure should be two lbs less than the cut-on pressure,i.e if your system operates at 30-50, then the pre-charge pressure should be at 28lbs. Adjust pressure as needed. A small air compressor is ideal to use if more pressure is needed.
Posted on Aug 16, 2009
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
Apr 04, 2018 | Kenmore Washing Machines
HI I have a Kitchenaid artisan espresso machine it makes a very load noise when I press the buttons for coffee and froth any suggestions ? thank you
You don't say if there is any water flowing along with the loud noise. If there is none then my suggestion would be that it's a dry water pump so you will need to force some water up the clear pickup tube into the pump while it's making that loud noise. The pump valves will be dry.
Nov 20, 2017 | KitchenAid Coffee Makers & Espresso...
Pay Pak heater makes loud groaning noise when turned on
Check water flow, possibly too low of water flow. Possible dirty filter.
Oct 30, 2013 | Pool & Spa
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
Jan 05, 2010 | Moen 87555C Trianna Single Handle Pulldown...
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Jul 15, 2009 | Plumbing
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Jul 23, 2008 | Kenmore 15864/15862 Top Load Washer
Plumbing Logo
326 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
