2011 Kia Sportage
SOURCE: Headlight and dash lights
Check your fuses! If not check wirering at head light I had this problem after my husband ran mine thruogh a huge puddle. It was my fuses
SOURCE: headlights & dashlights turning on & off
Daytime running light module which is located under dash (around the area of the fuses) probably has a bad solder joint inside (if you take it apart). If not could be bad connection on one of the switches (like your dimmer switch)
SOURCE: 200 Kia Sportage door lock remotes will not work
Did you replace them with the same batteries ? Some people assume all batteries are the same. Some are 3 volts, while others are only 1.5 volts.
SOURCE: changing headlight on kia sportage and fixing the
replacing passenger side headlight on 1999 kia sportage
SOURCE: Finding the transmission fluid dipstick for a 2011 kia sportage
Lot of newer cars don't have they now days. Should be plug on side of case. Its a dealer item nowdays.
