Question about Vivitar ViviCam 3750 Digital Camera
I bought a new sd card and when i put the card in the camera it has an error. my old sd cards still work in the camera. i have bought four different sd cards and tried them in the camera(still getting an error message)put in old sd card and it worked fine.
    Problem Solver:
  • 13 Answers
Try formatting the card in your PC
Most camera Mfr's do not recommend this but I have found it to work.
If you have an adaptor that will allow you to plug the card into your pc just do so and format whatever drive letter it assigns
Posted on Jul 15, 2009
  • 4,924 Answers
Try to format them into your pc...maybe they are still raw and that why they do not work ...also ..read the manual and see what is the max value supported.. be sure they are formatted .in FAT ..system ..
I get memory card error when trying access my SD card
do you mean you switched to a NEW sd card or to a DIFFERENT one you had laying around? sometimes if you put a card into a different device, say maybe a laptop, and you don't go to 'safely remove disc' on the computer it will wreck your sd card when you remove it. make sure you try a new card from a package before you do anything else-if that doesn't work your camera has a problem.
Jan 04, 2015 | Video Cameras
Gateway digital camera DC-T50 5.25 megapixels put new memory card and a card error message appears
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
Apr 04, 2012 | Gateway DC-T50 Digital Camera
Bush card error message
Not compatible with the new camera.
Oct 20, 2017 | Video Cameras
Bought new SD card for my Gateway DC-T50 but when i turn it on give me card error
bought new sd card for gateway dc-t50 camera. camera dept said camera is too old for the sd cars.
Jan 16, 2011 | Gateway DC-T50 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Mar 22, 2009 | Kodak EasyShare C310 Digital Camera
New 2 GB Memory cards say cards full when installed
The SD card may have to be reformated. You should do this in the camera you want to use the SD card with. Do not format the card with your computer.
In you manual or on the menu of your camera there is a "Format" procedure. follow that and your camera will work again (REMEMBER) if you have images on the SD card down load them before you format the card.
Once you down load the images from your camera you should reformat the card to clear it in order to shoot more images.
Mar 20, 2009 | Kodak EasyShare C330 Digital Camera
Memory card
Unfortunately, the A520 does not support SD memory cards with more than 2GB capacity, and doesn't support SDHC at all. (1GB max for MMC cards.) I know memory is much cheaper than when the camera first came out, but in 2005 2GB was about as large as you could get.
Jul 20, 2008 | Canon PowerShot A520 Digital Camera
Vivitar ViviCam 3750 Digital Camera Logo
198 people viewed this question
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
