Question about JVC TH-C3 System
Our power went out briefly and now the DVD player won't turn on
Our power went out briefly and when it came back on, I could not get the DVD player to turn on....it was plugged into a power bar with other items which all work, but the DVD player will not....what's wrong?
  • 979 Answers
Hello sir/ma'am, my guess is that the dvd player's power supply fuse gave in. Im not familiar with your dvd player, if you can open the dvd player and locate the check the fuse. replace it if its blown up. hope this helps. if you may have any more inquiry feel free to ask me again. best regards, thanks.
Posted on Jul 15, 2009
My jvc dvd player xv-thc50 won't turn on
if your dvd player has no any power indicator at the front, the first place to be checked will be the power supply. look for a blown fuse bad component parts like shorted diode and an open resistance.
Oct 15, 2012 | JVC Televison & Video
Won't turn on
see this causes and fix it. God bless you
  1. Power outlet, wall adapter, or batteries are dead (as appropriate).
  2. Damage to line or wall adapter cord or plug.
  3. Bad connections or faulty component in power supply (including blown fuse).
  4. Defective microcontroller.
Sep 23, 2012 | Samsung DVD-H1080R DVD Player
I put in a DVD that I usually use. It went to the DVD menu but then froze up. Now it won't open and sometimes the power doesn't even come on.
From the description you have provided, the microprocessor controller ic is failing which is the brains for the whole system. I suggest repacing the complete unit rather than have it repaired because it would not be cost effective.
Mar 03, 2012 | Sansui VRDVD4000 DVD Player/VCR
When I turn on the power button, the LED on the front of the unit lights up and indicated the volume level, then briefly the "Welcome DVD" message, then turns off. This all happens in 2 or 3...
I'm sorry that the DVD player is not working as expected. Please follow the troubleshooting steps and check the operation:
  • Please make sure that the connections are secure and proper.
  • Perform a power resetting and check the operation. To perform the power resetting, unplug the DVD player from wall outlet for more than 2 minutes and then reconnect it.
  • I also suggest that you try connecting the DVD player to a different Wall outlet and check the operation.
  • If the issue persists, please open the box and check for any loose connection.
Thanks for understanding.
Please get back to me if the issue persists.
Nov 07, 2011 | Yamaha DVR-S150 DVD Player
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
Power went out briefly and now the unit won't come back on. Is there a reset button?
unit may have power saver box and until you either open unit and manualy engauge contactor or call your local power company it wont start.It has to feed power off unit to start
Jun 04, 2011 | Weather King 10AJA6001AH Air Conditioner
I just bought an XO1915BT DVD player and installed it. I have the pink brake wire grounded with the other ground. It worked fine for me until I tried putting a DVD in. It played the FBI warning on the DVD...
http://www.xovision.com/pdf/XO1915BT.pdf
this is your owners manual for your radio
it shows me the pink wire is not for parking break but remote control for amp
gray wire is your parking break wire
i think you fried you dvd/radio
email me with more info caraudioquestion@gmail.com
Oct 14, 2010 | XO Vision Car Audio & Video
Disney Princess dvd player will NOT turn on or eject.
On front of television is the video, left and right audio plug ins. This is where you will plug the adapters from your dvd player. They are color coded for easy installation. Step2Make sure the adapter is also plugged in to back of dvd player. Step3Plug dvd player into power source and turn on. Step4On the front of television there is a tv/av button. Press this button twice or until it says video 2 in upper left hand corner of television. Step5Insert movie into dvd player and enjoy. To get your tv back to cable press tv/av button once.
Apr 20, 2008 | Disney Princess MCP DVD2050P DVD Player
Truck dvd player concept/pronto
Does it possibly have a reset button you could press with a paperclip? If not, try disconnecting the constant power wire for ....let's say an hour, and hooking it back up.
Nov 28, 2007 | Concept Slot Load Half-Din DVD Player Car...
My DVD player does not charge!
I think you mean the "charge/power" light doesn't come on? One thing I've noticed on the PD-758LP I have, is that the power connector on the back of the player is none too good, my DVD player quits if the cable isn't set just...right... Try moving the power cable around on the back and see if it lights-up briefly. I suspect problems with that connector first.
Jan 14, 2007 | Protron PD-758LP
JVC TH-C3 System Logo
245 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
