Question about NRS Stamina Upper Body Recumbent Bike 15 9100
My stamina bike, model R360s will not loosen the tension with the left button. It makes the motor hum but will not loosen tension. what's the fix?
Tip
StarTrac NXT Chain Tensioning & Alignment Video
About This Video
Adjusting Chain Tension and Alignment on a StarTrac NXT
  • In this video, we show how to tension and align the chain and flywheel on a StarTrac NXT bike
  • First you see an example of a chain that is way too loose
  • To correct this loosen the flywheel bolt on both sides of the flywheel
  • Loosen the tension nut on the sprocket side of the bike and tighten the tension bolt until you get the proper deflection on the chain
    • A properly tensioned chain will have roughly 3/16" of deflection
  • Tighten the tension nut and the flywheel nut on both sides as shown in the video
Check the Alignment of the Chain and Sprockets after Making a Chain Tension Adjustment
  • Misaligned chains will look like they are walking from side to side where they enter and leave the sprockets
    • This can cause noise, premature wear, as well as making the chain look to be jumping from side to side during use
  • To correct this, loosen the flywheel nut on both sides of the flywheel, then loosen the tension nut and adjust the tension bolt to move the flywheel in the proper direction needed to align the chain with the flywheel sprocket, as seen in the video
    • Note: If you have already achieved proper tension of the chain, adjusting the tension nut on the opposite side from the sprocket will help to keep the same tension on the chain
  • Don't forget to check the chain tension after making an alignment adjustment
Chain Tensioning Alignment Video for StarTrac NXT Bike
on Feb 11, 2015 | Startrac Fitness Products Star Trac 4410HR...
My 1/3 hp craftsmen door opener just hums when you hit the wall button or remotes in the car. I replaced the starter motor capacitor and nothing changed any ideas?
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain until the tension is removed from the trolley. Run the motor until the door is closed. While the door is closed locate the 'up limit' adjustment on the side of the motor unit and turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chain is to loose. How do I tighten the chain tension?
LOOSEN THE 2 BOLTS HOLD WHEEL ON PULL BACK ON WHEEL WHILE TIGTHEN BOLTS BACK UP. CHAIN DONT HAVE TO BE SUPER TIGTH . ABOUT 3/4 OF SLACK IN CHAIN.
Nov 18, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
Stamina R360s UP/DOWN magnetic restistance buttons not working
mine did the same thing.. unhook the plugs that are under the seat running from the handles and touch a screwdriver to two of the prongs on either side of the plug and it will engage the button for you on which ever side you do it.. the up or down side
Apr 21, 2009 | Stamina Products Stamina Pro 5300 Silent...
I need the wheel bearing assembly for a Stamina bike model 890.
If your mechanically incline, Pull out old wheel bearing, if still in half way good condition, take to bike/auto shop see if they can find suitable replacement or rebuild the bearing it self. make sure when putting back in to use very good grease. I have same problem, since I can't find parts, those would be the best possible solutions.
Mar 16, 2009 | Stamina Products Stamina Pro 5300 Silent...
I need a manual on my stamina r360 recumbent bike how to clear the settings on the in touch monitor
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
Feb 28, 2009 | Stamina Products Stamina Pro 5300 Silent...
NRS Stamina Upper Body Recumbent Bike 15 9100 Logo
328 people viewed this question
Top NRS Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a NRS Exercise and Fitnes Expert? Answer questions, earn points and help others
