Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Light in the digital control panel- Samsung Refrigerator RS2545S
The light in the digital control panel went out on my  Samsung Refrigerator RS2545SH.... how do i get it open to replace the light
SOURCE: samsung RS2545SH refrigerator just stopped making
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Posted on Dec 28, 2009
  • 5 Answers
SOURCE: Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Posted on Aug 13, 2008
  • 22 Answers
SOURCE: Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Posted on Nov 13, 2008
tborn6
  • 700 Answers
SOURCE: I have Samsung RS2545SH. Refrigerator
reset the refrigerator by holding in the two upper buttons unitil the display blinks. then it should reset and you should have everything working fine. please don't forget to rate the solutions when yopur question has been resolved. Thanks for using FixYa
Posted on Jan 01, 2009
  • 3 Answers
SOURCE: error codes for Samsung Fridge
does anyone know what error code 3 is? Have the same problem, wont cool on fridge side freezer side is fine...
Posted on Mar 01, 2010
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
POWER OUTAGE RESET CONTROL PANEL
I was looking for a reset of 33e on a samsung RFG298HDRS, no luck all the advice didn't work for me I tried them all and then started my own combinations, holding down energy saver and lighting button for about 10 seconds worked the error code went a way and the refrigerator panel started working again.. I hope this will help someone.
Sep 13, 2014 | Samsung RS267TDWP Side by Side...
Samsung RSH1DBBP Digital Display problem
The display panel has damaged. It has to be replaced by same type and number. There is no repair to it. OK.
Feb 01, 2012 | Samsung RSH1DBBP (19.1 cu. ft.) Side by...
After a power outage, the control panel on front has only blinking lights. How do I reset the control panel to control the temperatures?
The control board went into self diagnosis when the power was applied. It found an error in one or more of the systems. You will need a qualified technician to come out and see what the problems is. To bypass this problem for now, press the "Super Freeze" button and the "Super Cool" button together for 6 seconds simultaneously. This operation will put the refrigerator back to normal operation till the power is interrupted again. Good luck.
Jun 19, 2011 | Samsung RB215LASH
Refrigerator control panel
88-89 Flashing Reverse 9.
I noticed this occurs when the Ice Machine get jammed up.
Remove all ICE from Tray and Clean.
Press and Hold Energy Save+Alarm Button for 10 Sec.
Jul 18, 2010 | Samsung Refrigerators
Model rs2534ww side-by-side Samsung frig. After power interuption to the home, interior lights work, but digital display is blank and compressor won't run. How do I fix this?
Regarding Samsung refrigerator model rs2534ww/xaa repair: Basic trouble-shooting from Fixya was helpful, but solution required service call from repairman. (Very few repairmen work on Samsung at this time.) We thought problem was the digital controller, but turned-out was ice maker (!). Repairman explained Samsung has wierd control design that is based upon ice maker sensor. Sensor alone cannot be replaced, required entire icer, which he had in the truck. Icer cost $105 retail ($86 online), but controller would have been $161 retail (couldn't find controller online). Hint: if control panel is "dead" except for (only) the upper (horizontal) LED segment of the right-most refrigerator temperature digit, the problem might be your ice-maker. If you find the ice maker online and can install it yourself, you can save at least $130.
Dec 03, 2009 | Samsung Refrigerators
Power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Aug 14, 2009 | Samsung Refrigerators
Control panel not working and no lights
Hi. you will need to replace this non functioning Control Panel asap and, test the light pressure switch for it's operational value. If the switch is OK, simply replace the bulbs.
May 24, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Refrigerators Logo
345 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
