Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Bought my Cub Cadet 18M from Home Depot in September, 2008. Only used a couple of months. Trying to start the thing now and it is impossible. Will start for a few seconds and then shuts down. I live in Florida. I bought this mower because it was supposed to be easy to start for myself and my daughter, two females.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I was ‘gifted’ with a non-working Cub Cadet 18M mower a few weeks (July 09) ago by a neighbor. The mower was purchased in the Summer of 2007 and exhibited the same problem as yours (started briefly and then died) in late 2008 and was then abandoned in the weather until it was given to me.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The carburetor is held against the ‘intake’ side of the cylinder head by two threaded studs via a gasket, a stamped sheet-metal heat shield (approximately 3.5 x 5.75 inches), a short black plastic manifold, and another gasket. The heat shield tends to vibrate in resonance with the engine vibration; this vibration eroded the gasket between the heat shield and the carburetor mounting flange to allow ambient air to enter into the gas/air flow into the intake side of the engine. This extra air “leaned-out” the gas/air mixture causing the engine to die.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I disassembled the components and removed and discarded the heat shield and its gasket and made a new gasket out of oil-wetted index-card stock. The machine now starts on the first pull and runs well.
Posted on Aug 04, 2009
I have a Cub Cadet LTX1040 that does not charge the battery while running and I don't believe it ever did. I bought it brand new from Home Depot in November in 2013.
you are out of luck as this machine is four years old. you should have taken it back when you first realized it was not charging. You have to get it checked out. I did have an old machine that never charged itself so I purchased a little battery charger you plug into the hydro and kept it charged up that way. It worked for me.
May 16, 2017 | Cub Cadet Garden
I bought a cub cadet rzt 50 zero turn mower at auction but there is no serial # on it how can I get it
Impossible. Or contact the manufacturer for info where the # is supposed to be.
Feb 24, 2017 | Cub Cadet Garden
22hp cub cadet cannot get started. severe backfire out exhaust when attempting to start. Ran fine when last yoused about two month ago ?
Hello. Thanks for using fixya. First thing i would do is make sure it has gas in the fuel tank. If that's ok. I would replace the spark plugs next. Could be that they are fouled out causing the no start problem.
Jan 29, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I need a belt diagram for a cub cadet lawn mower, model number 1515
download this manual below
http://www.manuals-depot.com/product.php?cPath=31_32_42&products_id=279
May 30, 2010 | Cub Cadet Lawn Mower Blade Drive Belt...
Timeing pull cord rip out of hand when trying to start mower model 18m
what you have done is sheared the flywheel pin top of eng pull fly wheel you will find a schered pin go to lawnmower shop possible with pin get replacement just a few dollars you be back in timing and back to work let me know if you need a walk thru sparks
Apr 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Aug 21, 2009 | Garden
Cub Cadet Selp Propell and Electric Start Stopped Working
Take a look at your owners manual. It should have a parts diagram in it. With the manual in hand take a good look at the self propel assembly. Make sure every thing is there. It could be a spring came off, or belt broke. You might have to take off some covers to check. If you are somewhat mechanically inclined it shouldn't be a problem. I suggest taking a photo with a digital camera to make sure you get everything back the way it should be. Also in your manual it might have a troubleshooting page.
Good luck. Let me know if this helps.
roundo4
Aug 08, 2009 | Garden
Finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Jun 12, 2009 | Garden
I cant start my cub cadet cc989
sounds like a plugged high speed jet
Aug 30, 2008 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
945 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
