Question about Westinghouse Refrigerators
Water leaks inside the fridge the drip tray has never got water in it the fridge is cold but dosent seem to be as cold as it use to be.the freezer is cold but it dosent get cold enough to see any ice
  • 1 more comment
  • muscles8 Jul 15, 2009
    thanks for your reply which panel do you mean the one inside the freezer itself or the one on the back of the entire fridge thankyou
    hi i cant seem to mop up water in pan because the evaperator is in the way can i move the evaperator i have tryed but attatched pipes wont allow it and i still cant see drain hole any tips?
    cant see drain hole because there is silver foil at the bottom of the pan what next cheers
    President:
  • 744 Answers
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Posted on Jul 15, 2009
  • Mike Price
    Mike Price Jul 15, 2009
    it's at the rear inside the freezer....should just be a few screws ;)
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
Our fridge is leaking water to the bottom - there is no water in the drip tray just on the bottom shelf - it seems to be coming from up above and dripping down the back on the inside. Any help
Clean drain starting underneath freezer coils. Compressed air is best but you can use hot water and blow in a tube until it is clear
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Maytag Refrigerators
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Intermittant water leak front left hand side and ice build up on inside base of freezer compartment, but no evidence of water leaking out from door it seems to come from underneath the appliance.
Sounds like the drain hose from fridge unit to evaporator pan built on top of compressor is plugged. The drain holes are small and clog easily. I like to make the holes bigger. A pipe cleaner helps to clean the inside of the drain hose.
Make sure water is dripping onto evap tray.
Nov 25, 2009 | Refrigerators
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Refrigerators Logo
78 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
