SOURCE: gas engine will not start without pulling trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
SOURCE: After switching from a 1.2tip to a 1.4 tip when i
adjust the knob that holds the needle inside the gun
SOURCE: when tank pressure is on gun sprays without trigger pulled
The only seals I know of that would cause this are around the spindle assembly. If you have changed these then you may have a problem with the seal retainer, a weak spring or bent spindle. Also make sure there are no metal shavings to hinder the sealing. Sometimes they can be left in the gun during machining process.
Hope this helps but if not please let me know and I will try and trouble shoot further.
Porosity, damage, misalignment
Channel Plate and Gasket, and Valve Body, Gaskets, and Channel Plate
Porosity, fluid leak across the channels, misalignment, damage, or fluid restriction
Low and Reverse Band and Servo
No apply or slipping
Servo Piston (69)
Broken or binding
Servo Piston Seals (71, 72)
Leaking
Servo Pin (67) and Springs (66, 68)
Binding
Servo Cover (73)
Broken, loose, or leaking
Low and Reverse Band (111)
Broken, worn, or out of position
Anchor Pin (64)
Broken
Fluid Feed Tubes (83)
Broken, bent, or plugged
Missing or leaking seal rings
Transmission Case (1)
Porosity, fluid leak, or restriction
Shift Linkage
Disconnected or misaligned
Manual Valve (800) and Link (802)
#1 Checkball
Missing, no low band fluid
Fluid Level
Low
Fluid Pressure
Low
Refer to High or Low Line Pressure .
Most likely your trans needs to be rebuilt !
to
