Question about Bose 901 VI Main / Stereo Speaker
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the equalizer. Can I download the hook-up instructions somewhere, or is this easy enough for someone to just guide me through it? The receiver I am hooking it up to is a Kenwood VR 306 which is about 9 or ten years old. Thanks for any help you can give me. Michael, San Jose, ca.
  • 3 Answers
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Posted on Jul 16, 2009
    Brigadier General:
  • 8,546 Answers
This works for all models of AV receivers when you want 901's as Front L&R speakers..
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
Posted on Nov 30, 2009
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
Bose 901 equilizer connections to sansui G901DB
It sounds like you may have only the 901 loudspeakers, and not also the companion 901 equalizer box. You must install the 901 equalizer properly--using the tape monitor loop of the G901 receiver. If you of not, the 901 loudspeakers will perform poorly.
Jun 17, 2014 | Bose 901 VI Main / Stereo Speaker
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
I want to hook my bose 901 VI along with EQ to my Luxman R117 Receiver and also run other speakers from the same receiver. Is this possible?
If you are using the Bose Equalizer to optimize the sound of the 901s by going through either a tape loop or a pre-out/main-in loop, then the only way to do this without also equalizing the sound sent to the second set of speakers is to manufacture a "zone-2" output from the Luxman.
You'd probably need to split the send from the Luxman's pre-out before the EQ and send it to a second power amplifier for the second pair of speakers (if you want the Luxman's volume knob to control both speaker sets) or from a tape level output (if you wanted independent volume controls for the two speaker sets.
The whole EQ thing made 901s difficult to use on vintage equipment with only one "zone" audio outputs. Unless you want to use the Bose EQ on the second set, too, you can't do it satisfactorily without adding another stereo amplifier. But, go ahead and try it, you might find that you actually like the odd EQ that the 901s EQ gives to the second pair!
If it were my decision, I probably would not do it without a second amp, but it's all about what you like, my opinions really don't matter in your house, do they?
Have fun
Jul 24, 2010 | Bose 901 VI Main / Stereo Speaker
I have a set of 901 IV with no equializer, I am
As far as I know, any equalizer will work. There is a guy on here that might know more about them, but I never had the Bose equalizer and I have Bose speakers for 35 years. The guy at the electronic store back then sold us a little equalizer at first, we graduated from that a long time ago, and now on the 3rd or 4th one. No problem, works great, sounds better than ever. Hope this helps.
May 11, 2010 | Bose 901 VI Main / Stereo Speaker
I am looking to upgrade my receiver to an audio video receiver that will hook up to a blue ray via HDMI. I want to use my 901's forthe front speakers. Can you recommend a mid priced (<$600) AVR that...
Good day,
Congrats on your new AV receiver. I own an awesome Yamaha mid-priced AV surround sound system with HDMI, BR disc player, and all that stuff. However, I'm old school and use my 901 Series Vs with a Yamaha RX-797 'two-channel' receiver. To get to the point, I have some bad news. Mid-priced (mp) AVRs, or any AVR for that matter, will not work with 901s because the active equalizer (EQ) requires either a 'tape monitor loop' or 'pre-out / main-in' connection to work properly. You've probably been told the 'why they won't work' by now and it is very true--I know from experience. Most of today's AVRs do not include a 'tape monitor loop' or 'pre-out/main-in connection for the EQ connection, thus, killing all hopes of using 901s. I truly love my 901 Series Vs (since 1985 and still kicking) and love true 'stereo' for playing my music. Again, 901s are useless with today's AVR equipment (as I know it). Just don't let your 901s collect dust--they are truly marvels!! Go with a set of good 'standard' speakers for the AVR system and buy yourself a decent stereo receiver or amp for the 901s--that's how I do it!! I've tried Onkyo, Rotel, Sansui, Poineer amps / receivers--all of them. I can tell you this--for the common, working man/woman, nothing, I mean nothing available can match-up with Bose 901s like a Yamaha RX-797 (200W)--not to mention the sound quality-wow!!! And this unit is very reasonably priced for such awesome performance and high quality build. Just know that all is not lost. You can still use your 901s--I cna't listen to music without mine.
Aug 24, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 and Tube amp
Yes! When the Bose ~Steve901 first came out that was the amplifier of choice -like the McIntosh classic amps. The 901s have their own equalizer as that speaker system is a phased-array,
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
489 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
