Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Remote is not working with tv
Remote is not working with t New batteries and was working fine. I even tried another universal ad it won't respond to the remote.
    President:
  • Philips Master
  • 1,779 Answers
You probably have a defective IR receiver in the set, have it looked at by your local service company.
Posted on Jul 15, 2009
LCD2710HDAF television will not respond to remote control
Hi Alan,
Here are a few steps to troubleshoot.
1) Make sure that the new batteries are correctly installed.
2) Make sure that there is a line-of-sight between the remote and the TV while operating.
3)Not recommended- but might work. Give your remote a little shake. If there is a small circuit loose connection it will be adjusted. :P I do this all the time.
4) Buy a new remote. You can buy a universal remote which are available on the market. They are cheap. It will NOT be harmful to your TV.
OR
you can buy a genuine one.
May 12, 2014 | Televison & Video
Remote does not work
Infrared sensor inside the TV is damaged. Replace it.
May 17, 2013 | Televison & Video
My remote won't work. Batteries are new.
Check its battery contacts inside the battery compartment for any rust or dust accumulated, which prevents good electrical contacts with batteries. Insert batteries after cleaning them well. If it do not help you, check for its infrared emission. If you wish to get more details about how to check a remote control, visit this site. Pull up older posts there. One among has detailed description.
Mar 30, 2013 | Televison & Video
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
The TV stopped receiving IR signals from remotes
make sure that your remote has a line of sight to the tv. often a small antenna is added to enhance reception. also check to be sure your remote batteries are aok.
Sep 09, 2009 | LG 42LC2D 42 in. LCD HDTV
My tv stopped responding to the remote for some odd reason ( the remote seems fine ) how do i reset it ??
the problem is the IR Receiver in the tv needs
replacing,this is the receiver thay receives the
signal from the remote.there is no reset for
this type of problem.Also you my try new batteries in the remote and a new remote if the
IR Receiver does not repair the problem.
Sep 04, 2009 | RCA Universal Remote Control
TV does not respond to remote
Sounds like the sensor on the television has gone bad, since it works for the VCR. Try a universal remote that you can program the TV and VCR codes into and try it out. If it works for the VCR and TV then you know it's the remote, if the TV still isn't responding then your TV sensor is toast.
Jan 03, 2008 | Zenith B27A11Z 27" TV
No response from remote
Check whether the remote control is working properly or not by using remote checker. Even if it is the universal remote control you have to set the code for the particular model. Otherwise it will not work.
Sep 17, 2007 | Panasonic CT-32SF37 32" TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
