The TV will not power up and the led indicators are not lighting up. I have checked the smp board and all voltages are present and correct. Dave
    President:
  • 2,777 Answers
Sounds like it could be something as simple as a switch that failed. Does the TV usually have standby indicator lights? If not then I would definitely check the switch. If it does have regular standby lights and they aren't lighting up that's definitely a bigger issue. You are sure the voltages are correct everywhere? Are you using a diagnostic manual as a reference, how do you know they are correct?
Thanks
Tim
Posted on Jul 15, 2009
LG 55LW5600 problem Symptoms: no audio, no video, no backlight.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 12, 2017 | LG Televison & Video
LG 32LB530A Tv sound ok faint picture Led backlid off
Back light led driver or the led array is faulty. check and confirm the voltage to the led back light from the power supply. normally 35V to 100V according to the brand and model of the tv. Check the voltage if the voltage is somewhere around the above mentioned voltage the then the tv have problem with the led array behind the screen . If the voltage is missing then the led driver is faulty. Normally the led drivers is found integrated to the power supply board. If so then you have to replace the power supply board as a whole.
www.electro-medical.blogspot.com
Oct 10, 2015 | LG Televison & Video
Olivia 242-T11 MOTHER BOARED HAS 2 BLINKING RED LIGHTS WHAT DOES THIS MEAN?
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 23, 2014 | Olevia LT37HVS 37 in. LCD HDTV
Dead set toshiba mod. no. 52xv540u no bad caps,no clicking,no led lights on front
Hi, First check that you have good power coming in from plug.
If that is good check out power board (capacitors Bad) replace if oozing out or bulging out. If you are good with soldering then do so.
Replace with same capacitors or better ones.
Jan 13, 2014 | Toshiba 32AV502R LCD TV
No power and no glow to the screen. I'm assuming a power supply problem and I'm looking for a tear down of the unit. I also understand there are some fuses inside the case as well. Visual...
U have power to the tv is that correct?Yes?Power led light indication solid green,when tv is on but u have a blank screen no picture to the LCD screen panel at all?Yes?Than this problems it is not the tv power supply board problems.The tv Tuner signal board is it the cause and the problems.That the board where the incomming broadcasting signal cable plug into it.This board are 90%-95% are not repairable or troubleshoot able,because it almost all micro components parts and micro chips and most of them are surface mounted it on.This tv Tuner signal board can be only replaced with a new whole refurbish one only.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 11, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
My TV on button is not turning the TV on. I tried the remote as well as the button on the TV.
Now,what happening to the tv power LED light indicaton,when u turn on the tv now?Tv don't have any power LED light incation at all or power LED light indication is flashing?Check ur power source with other devices,see if the outlet is the problems,if tv still have no power to the tv all.Tv LED power light indication is flashing?Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Now tv should work be again.Still have the same problems,this indication ur tv have a bad or a dead power supply board.That the board,where the tv power a/c cord plug into it.If u understanding basic electronic and have all the tools.Take the tv backcover aparts.Check the tv power supply board carefully for dying capacitors parts,these capacitors parts are dying or dead,most of the times they're bulging up or puffing up onto it tops.Replaces these capacitors parts with new capacitors parts with the same micro ferid but higer voltages like about 5 or 10 voltages higher for better heat resistances and last longer.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 13, 2011 | LG 37LP1D 37 in. LCD Television
TC-P42C2 Power Indicator Light Flashes 7 times, No video or audio
Power LED light indicator are flashing it is the effect of the power supply board are dying and not giving the tv the wright amount of voltages anymore.That the board,where the power a/c cord plug into it.U have all the tools,u understanding basic electronic also can u do basic soldering?Yes,check all over the power supply board for dying parts call capacitors.These dying capacitors are alway bulges up or puffing up on to it tops.By replacing all these dying capacitors are bulges or puffing up on it tops,will solved this flashing LED power light indication,power supply board will work again.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 07, 2011 | Panasonic TCP42C2 42 in TV
42 plasma tv model42mf230a/37 blue light on no picture no sound
with solid blue led set could be still powering on but would need to verify by checking power supply voltages. if up and signal is present with no menu or audio would be ssb as audio amplifier, micro processor and eeprom are on that board. if voltages are not present you need to offload x and y sustain boards one at a time from power supply and check voltages and if vs comes up with either board disconnected replace that board
Jul 25, 2008 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
