Question about Sony Ericsson K750i Cellular Phone
Handsfree can't hear anything when i insert my handsfree
Re: handsfree
first check it your headset that,... whether its in good working condition.. then check ur mobile with another headset....
with this u can confirm where the problem is... but.. the problem may not be in the phone i think so....
just check it out,,,,
Posted on Nov 26, 2007
0 characters
3 Points
When i make a call and receive a call on handset i cant hear i have to put my phone on loudspeaker
this problem happens when you try to put a handsfee other than original in the head phone socket, just use any alchol based cleaning solution in the soket, then insert handsfree in soket repetedly removing and inserting many times, many times the problem is solved
Dec 22, 2010 | RIM BlackBerry Bold 9000 Smartphone
I am not getting handsfree signal if i insert also handsfree
check another handsfree or clean your handsfree connection...
Jun 09, 2010 | Nokia 5310 Cellular Phone
Please Solve...I cant hear my phone...
you have to go to settings and then go to sound settings and then switch off the handsfree option.
Aug 31, 2009 | Nokia 6681 Cellular Phone
My n95 handsfree mode works but when turned into handheld i can't hear anything through the phone
it is a problem with handsfree connector with is unable to "feel" when the handsfree is not connected, it is easy to change it
Aug 15, 2009 | Nokia N95 Cellular Phone
Can't hear anything in my bluetooth headset, mic is working
try going to the settings of your BT headset... hope that works
May 25, 2009 | Cell Phones
Handsfree or headphone problem in lg kg195
Apr 09, 2009 | LG Cell Phones
Fm player
You can't initialize the FM radio without the handsfree attached because the phone uses the handsfree wire as an antenna. You can achieve this by building a special snap on to the phone that activates the pins on the port on the bottom of the phone...but it would be pointless since without the handsfree there would be no reception meaning you won't hear anything...just lot's of static.
Dec 12, 2007 | Sony Ericsson J230i Cellular Phone
make sure you have the profile set to headset. Goto your look through your phone settings.
Dec 08, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Only works on loadspeaker
The problem is with the socket where you insert the handsfree. Sometimes the socket connection is not released internally after removing the jack. Please insert the handsfree to its jack socket and remove it. Try again.
If not possible, a repair technician has to do it.
Oct 29, 2007 | Nokia 6288 Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
