We have a Jandy AquaLink RS w/oneTouch Control Systems. 2 problems: AquaLink controls out by pool are not functioning properly. When switching from automatic to service mode to time out, you hear a clicking noise; and remote isn't functioning either; the backlight flashes, not all the programs are showing and it is slow to move from one function to another and sometimes doesn't function at all.
Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
www.manualslib.com > ... > LJ > Installation and operation manual
Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
IF it does have a spa, dies it also have a spa side remote? If so the first step would be to unplug the spa side remote from the back of the board. If the issue stops then you need a new spa side remote if it persists then it nah be be main circuit board or relay for the heat pump.
It sounds like the unit itself may be out. The acid test would to be to get hold of a new one and switch them out. See if you can find a local pool company to work on that for you.
This may be the temp sensor or "thermistor" on the heater or on the Aqualink. If you have a book not hard to replace.
Check with your local BBB or Regestra of Contractors. Also look for pool orgnazations like NSPI (National Swimming Pool Instute) or a local servicemans orgnazation. Or call Jandy or go on the web to get their local rep.
