Question about Cycling
How do i adjust the handle bar height - Cycling
  • 441 Answers
The handle bars run thru your neck in the center, you should find a hex head bolt inthe center of the neck, loosen it then pull the handle bars up, be careful not to unscrew the entire bolt in the neck
Posted on Jul 15, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: I cannot adjust the height of the handlebars on the 20" Mongoose
some bikes u cant only the seats can adjuct
Posted on Jul 20, 2009
Trayl bike owners manual. or how do I adjust the height of the handle bars?
Your bike has a modern "threadless headset" which usually allows very little vertical adjustment. See this page for an explanation of how to change height on that style:
How to adjust handlebar height BikeRadar
If you can't adjust enough that way you can try buying a shorter stem or one with a steeper angle,. The final option is to buy a "stem riser" - Google the term for more info - needs to have correct dimensions for your bike
It's best to get advice at a bike shop as to what option is best for you..
Jun 04, 2017 | TRAYL Cycling
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
Adjust handle bar height ?
looking at some pictures of this model, most appear to be using an "Aheadset" style handlebar stem, there is not any way to raise this type of stem. Your alternative is to go online or to a local bike shop and purchase a new stem that will fit your fork and handlebar that has a higher pitch angle to it, or a compatible adjustable stem that pivots. Expect to pay $25-$50 or more for a new handlebar stem, not including labor to install.
Apr 06, 2016 | Marin Belvedere Commuter Road Bike
How can i raise handle bars on my diamond insight
Today's bike stems have minimal adjustment height, if any. Look at your stem to see if it has spacers. These spacers can be moved up and down the stem. For more adjustments, you will have to buy a new stem. Here is a good place to read up on
Sep 26, 2014 | Cycling
I need instructions for sonoma 29" swivel bar stool
this bar stool can be adjustable the height. You can operate it by the handle under the seat.
Jan 20, 2014 | SONOMA life + style Adjustable Swivel Bar...
Can we buy adjustable handle bar for quinny zapp
There is no alternative handle / handlebar adjustment for the Quinny Zapp.
May 27, 2012 | Quinny Baby Gear
Handle bars need to be adjusted up in height
You need to loosen the neck of the handle bars with a anlenwrinch.After that you will be able to adjust the hieght of the handle bars by lifting the top of them.
May 30, 2010 | Disney Cars 16-Inch Boys BMX Bike
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Need to adjust height of handlebar on a jeep sahara bicycle
Most bikes use an allen key to adjust the height of the handle bars. Typically 6mm. But be careful most bikes do not have much adjustment that can be done to the height of the handle bars. The handle bar stem will have a line on it of the "minimum insertion". That line must be below the top of the head set nut for safety reasons. Look for the line as you adjust the height.
Oct 03, 2009 | Jeep Cycling
Cycling Logo
355 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
