Fan does not run
Motor kicks on but doesnt cool and fan on outside unit doesnt come on either
  • 92 Answers
You have a bad fan motor and it needs replacment(outdoor fan),sometimes though you can replace the capacitor(if it looks bloated or malformed).good luck--Nate
Posted on Jul 15, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Handler runs fine but the outside unit, it will kick the fan on for a sec and then shuts off. It does it over and over. sounds like something isn't turning on? what's going on?
Sounds like a bad relay on the fan , if the compressor is trying to start and stopping that kick the fan on and off. That could be due to a low charge if the unit is not cooling properly.
If the unit is cooling properly it is probably a bad relay or contactor on the fan motor.
Other possibility is the fan motor is over heating for one reason or another and if its thermally protected it will automatically shutdown. If thats the case then you need a new motor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 19, 2013 | Goodman Heating & Cooling
Electric fan wont kick in jeep over heats replaced thermostat and two sender units
Sounds like your cooling fan relay is bad the jeep grand cherokees are known for this, first thing i would do is unplug the radiator cooling fan and run 2 jumper wires direct from the battery to the fan connector if the fan kicks on your fan motor is good and the relay is bad, if the fan doesnt kick on replace the fan motor with a new unit, the cooling fan relay on your particular model jeep is located under the passenger headlight and requires you remove the front bumper to replace it, however some people cut a small hole under the headlight to access the relay the faster way but if your not to keen on cutting holes in your car remove the bumper and replace the relay if the fan checks out and you wont be overheating anymore...
Dec 07, 2010 | 1999 Jeep Grand Cherokee
Outside fan doesn't work. Inside it sounds like it works - there is a fan sound - but no cool air What part is broke?
If your compressor kicks on outside but the fan on top doesnt you need to ck the capacitor to the fan and the wiring to each. There is a schematic inside the elect panel on the outside unit it will give you an idea where the capacitor is it will be a silver or grey metal device with three wires coming out of it or you will have one small and one larger one with two wires coming out of each. the fan runs off a 5uf capacitor and the compressor a 35 uf capacitor. The most obviouse thing will be burnt or melted wires inside the elect panel when a capacitor goes bad it usually takes wiring with it. If wiring looks good buy a new motor and replace the capacitor at the same time. take the elect motor with you so it can be matched up.
Aug 08, 2010 | Ruud Matching Split Air Conditioner
My air conditioner is blowing hot air. The outside fan in not wo
sounds like a contactor problem. this is the switch that kicks the outside fan amd compressor on. If the inside fan runs it will be on the outside.
Jul 08, 2010 | Whirlwind FH-778 Air Conditioner
On my window unit the compresser only runs for 15 sec. and shuts off for 4 min. the fan stays running.. its not cooling the room
possably a problem with the outside condensor fan motor. Pls check
1.) when unit is running is the outside fan motor also runnng. My guess is the outside fan is locked bad motor ect. Unit would only run maybe 30 seconds before cycling on its overload
May 04, 2010 | Whirlpool ACE244XS Air Conditioner
Air on heat pump not cool outside unit humming but not kicking on
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
Aug 19, 2009 | Carrier 38CKC042 Air Conditioner
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
