Loses time and channels after couple days - Televison & Video
  • 42 Answers
Do you unplug the unit from the mains at any point when leaving it for several days?
Posted on Jul 16, 2009
I have a logik tv and have accidentally deleted 2 channels how do I restore them ?
You'll have to go to the menu and rescan for channels again. If you have cable this should be no problem. If you are using an antenna for over-the-air signals, you do potentially run the risk of losing other channels as those signals come and go and are stronger at times than other times. If it happens, you'll just have to rescan again, possibly at a different time of day or day of the week.
Jun 13, 2014 | Televison & Video
TV intermittently loses and regains audio/video from only a couple TV channels
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 28, 2017 | Sharp LC 46SV50U 46" LCD TV
How do I delete channels not wanted and get channels I have lost the past couple of days?
just press the menu either in the remote controller or in the tv panel. and then go to channel set up this time you can delete channel and can add channel you want and then save in the memory.
Sep 07, 2012 | Insignia Televison & Video
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
I have had a Sharp AQUOS LC-46PD7X for over three years and just a couple of days ago I started getting a problem where I turn the TV on and it either displays a digital channel for a couple of minutes and...
Hi ibrahl,
I too have the same model and vintage and have been experiencing low signal problems for quiet some time now. It only became apparent when we hooked up the ps3 playTV unit and the digital channels we were having problems with on the Aquos was broadcasting fine. Both devices use the same antenna connection so its not an aerial issue.
I tried reset back to factory settings and reloaded the channels via auto but now those digital channels I had problems no longer appear on our channel list so they're gone for now. I was wondering the same thing about firmware updates but havent found anything on the Sharp website. Found this video but this model uses USB for updates">
Jan 02, 2011 | Sharp Televison & Video
Belkin f5d8635-4 Router connection problems
Open the working pc open internet explorer and type 192.168.1.2 in the webaddress bar. this will open your belkin router settings page. On the left choose channel and ssid. If it asks for a password leave the password box empty and just click submit. The channel is the frequency your wireless network operates on. Some channels are more stable than others, but its just trial and error until you find the most stable for your area. Change your wireless channel to a different one (any channel is fine, personally 1,11 or 8 works best for me) and click apply changes. Hope this helps.
http://www.thinkbroadband.com/hardware/reviews/35-belkin-f5d7630-4a.
Apr 15, 2010 | Computers & Internet
Am loseing channels every time i scan the tv some channels come correctly others apparently havent signal orignally all local channells came in perfectly now a couple channells come in perfectly when...
Depending on the signal strength of those channels on the days you do the scan your tv may decide that it is not a good enough signal for it to even bother programming into your normal channel list.
The weather will honestly have a lot to do with pulling in over-the-air broadcasts.
Nov 04, 2009 | Vizio L32 32 in. LCD HDTV
Channel 2 goes fuzzy same time each day
This may be an issue with the broadcast. As all other channels are fine its not the tuner or TV. The broadcasters may be doing work on this channel at the same time every day.
I would advise contacting the people who broadcast TV in your area
Jul 15, 2009 | Televison & Video
Programming wrking fine, however i have no channel guide/listings
Call LG. They will have you go through diagnostics over the phone and ask for diagnostic data the TV has in memory.
I have done this about 10 times and my TV usually loses all it's TV guide data after I customize my channel listings (delete all the channels I don't susbscribe to). Within a day or two of calling them, my TV Guide is back to normal.
I will never buy another LG TV. Thank God I bought the extended warranty. I've had the power supply already replaced (this is also the 2nd set..replaced 1st set due to same issue), TV turns itself on at times ( in winter - low humidity/static electricity??), and loses TV Guide listings on a frequent basis (after I change the channel map).
Nov 26, 2008 | LG 42LB1DRA 42 in. LCD Television
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
