Question about TruTech Televison & Video
I can not turn off the closed caption. I have pressed the button over and over again, but the CC will not turn off. I went throught the menu and do not see anything there. I press the Factory Defualt button and it's still there. Can you help me?
  • harold_kenny Jul 16, 2009
    Thanks. That was it.
    President:
  • TruTech Master
  • 1,779 Answers
It should be in the Audio section of your Menu. If you are using any kind of cable box, make sure that their CC is off also.
Posted on Jul 15, 2009
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
I cannot turn off closed caption on screen. Panasonic Viera Plasma TH 42PV60A
hi,
To exit closed caption do the following.
1. Press the menu button and select CC and press OK button.
2. In CC menu select MODE and using right arrow or left arrow button select it OFF
3. Press OK button
4. Press menu button to exit menu option.
ok
Mar 10, 2011 | Panasonic Viera TH-42PX80U Plasma TV
How do I shut off the captioned dialogue on the screen for my magnavox smart series tv. there seems to be no such choice on the menu
hi,
For closing the Closed Caption option do the following.
1. Press the MENU button on the remote to see the menu.
2.Press the up arrow or down arrow until the CC (Close Caption) is highlighted.
3. Press the right arrow repeatedly until CC OFF appears.
4 .Press the menu button to exit.
Or, you also can set Closed Captions by pressing the CC button on the remote. Press CC repeatedly to select: CC-OFF,
ok
Feb 07, 2011 | Philips Magnavox 20MS233S 20" TV
Can't turn off closed captions or find option to do so please helphelp
hi,
u can remove the closed caption optoin by the following setup.
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
Dec 26, 2010 | Philips 32PT6441/37 32" TV
How do you get closed caption on
manual below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Turning On Captions Pressing the CC button displays caption options: ? CC on: Displays captions. ? CC off: Turns off captions. ? CC mute: Displays captions when the Mute button is pressed. To assign your preferences for captions, see “Using the Closed Caption Menu” on page 33.
Mar 17, 2010 | HP PL4260N 42 in. Plasma HDTV
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
I do not know how to turn off the closed captioning on my son's orion tv set. I do not know the model type. I do know that closed captioning options are not on the menu.
If you have the original remote look for a button labeled "CC" or "Caption/Text" press this button till the screen says caption off.
Jul 06, 2009 | Televison & Video
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL-
to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE).
CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL-
to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
276 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
