Question about SVA-USA SVA VR 15A 15" Flat Panel LCD Monitor
All of sudden the power cord seems to be shorting out where it attaches to the monitor
  • 426 Answers
Replace your power cord, recycle the old one :)
Posted on Jul 15, 2009
First the power cord seemed to have a short in it and would only work if the cord was supported and left in that position . Next it stopped beeping when the stitches were changed. Now it does not work at...
A short would cause a bight spark and burning of the cord at the place of the short.
Sound like you have a poor electrical connection at or inside the machine where the cord attaches.
Take it to a repair shop.
Mar 29, 2015 | Sewing Machines
Gets no power from wall or battery
Few things in life are as frustrating and infuriating as working ******* your laptop, only to see the screen go dark due to a sudden power loss. While there's a good chance your hard work and data is gone, the more concerning issue involves the cause of the sudden loss of laptop power. A suddenly dead laptop could indicate a more serious problem, or simply be due to a loose battery or power cord.
Overheating
If your laptop's fan was running hard and fast right before your laptop went dead, it's possible the machine shut itself down to avoid damage from overheating. The internal electronic components of a laptop generate heat when the computer is turned on, and this heat must vent to avoid causing damage to the machine. If the air vents are clogged or blocked and the heat inside cannot dissipate, the laptop will power down without warning to prevent possible damage. To avoid this problem, ensure that your laptop's fans and air vents are clean and clear, or use a laptop cooling stand to help vent the heat.
Battery Issues
Laptop batteries are not exempt from malfunctions, and a sudden power loss may point to a problematic battery. A loose connection may cause a surprise laptop death, as can dirty connectors. Like most other battery types, laptop batteries are not immortal and eventually lose the ability to hold a charge for long. Some laptops have sensors and circuitry to monitor the battery, and will cut power to and from it should it become too hot or exhibit too high a current. Try cleaning the connectors and reseating the battery properly to fix the problem. In the event of a loose connection, a repair technician may be your best course. For malfunctioning batteries, a new replacement battery may be the best way to prevent future power failures.
Electrical Problems
If you were using your AC adapter for power right before your laptop powered off, there may be an electrical problem somewhere along the line. The outlet you were plugged into may have short circuited, or the adapter itself may have overloaded. The connector on the back of your laptop may be loose, preventing proper connection of the adapter. A short circuit within the laptop itself may have occurred, preventing either the battery or adapter from providing power to the rest of the electronics. Work backwards to find the source of the power supply problem. Try a different electronic device in the outlet, and insert the adapter itself into a different outlet. Reinsert the various cord ends into the adapter and laptop to ensure a tight connection. If a short circuit seems the likely cause, seek the help of a professional technician for repair.
Troubleshooting
Try to ascertain what occurred right before the power loss. A physical move of the laptop may have loosened the battery or jostled the adapter cord loose. Try removing and then reseating the battery and tightening the adapter cord. A loud fan noise may indicate that the machine was on the verge of overheating. Let the machine cool completely before attempting to reboot. An unusual noise emanating from within your laptop may indicate a short circuit. A beverage spill can cause the death of an laptop if not attended to quickly, causing short circuits and power failure.
Precautions
Observe standard safety procedures when dealing with electricity, and never disassemble or examine an outlet or your laptop without disconnecting all power first. If delving into your laptop to check for short circuits and loose connections, work in a clean, open area to avoid introducing any new contaminants to your laptop's vulnerable interior.
Read more: My Laptop Suddenly Has No Power ' eHow.com http://www.ehow.com/info_10023896_laptop-suddenly-power.html#ixzz1XFwtBENN
Sep 07, 2011 | Computers & Internet
My toshiba laptop's screen shut down suddenly while i was playing a game, now i cant turne it on , i dont know what to do?
  • Disconnect all the power supply (battery and power cord) and attachments.
  • Press and hold down the power button for 30 seconds
  • connect with the power cord only
  • restart the computer
It seems the video card is not supporting the game's video requirement
Sep 24, 2010 | HP Pavilion dv6000t Notebook
Short in wiring
Look for bad solder joints, common problem due to poor design (the AC inlet is held in place by three solder joints, it should have been screw-mounted to the chassis)
http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
May 16, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Gateway monitor (FDP1965) Power/video problem
You have a problem with your lcd..get it fixed by technicians...
Aug 28, 2009 | Gateway FPD1975W 19" LCD Monitor
There is a loud buzzing/static sound coming from my monitor. It changes pitch and sound a little with different screens. The visual display does not seem to be effected. Just a terrible sound. Any ideas...
Start by getting a can of the electronics spray air and blowing out and areas that may collect dust.
Also jiggle the power cord attached to the monitor and watch to see if it changes the monitor or the squealing at all.
Seems more like a lose power connection, but eliminate the simple possibilities before moving toward circuit board issues etc.
Also do you have any other high powered electronic devices near the monitor?
That can effect it's performance as well.
Jul 23, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
My AL1703 sm monitor will not power on.
that means the power cord is faulty, the monitor does no send message to the power cord rather the power cord sends message to the monitor so its the power cord that's bad expecially if its an adaptor, thanks
Jul 17, 2009 | Acer Value AL1703SM 17" LCD Monitor
Tower intermittently loses power
i think you have a problem in you power supply sir try changing it or try separating your monitors source of power.
Dec 10, 2008 | Computers & Internet
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
Won't turn on
Could be a power supply issue. Maybe it's not getting enough voltage from the power supply unit. Could also be some bad solder points on the circuit board, or maybe a burnt capaciter.
Oct 04, 2007 | ViewSonic VX924 19" LCD Monitor
SVA-USA SVA VR 15A 15" Flat Panel LCD Monitor Logo
64 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
