Question about Kenmore Elite 45986 Front Load Washer
How do I remove the pump from a kenmore 70 washer?
  • 5,911 Answers
The Kenmore 70 series is a top loading washing machine. Different from the picture you have this listed under. If this is a Kenmore top loader, the following link explains how to replace the water pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this is a front loading Kenmore, the next link applies:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Posted on Jul 15, 2009
Kenmore washer
most likely you have a sock or, some cloth obstructing the pump.
you will have to bail out the water then: remove the Sears 700 series 4screws holding the washer's control panel and, remove the washer side clips under the panel to remove the washer's sides then remove the 8 pump screws to remove the pump face and, remove the obstruction. the
exploded drawings can be found at: http://beta.searspartsdirect.com/partsdirect/index.action
Jul 14, 2010 | Kenmore Washing Machines
70 Series Kenmore washer pouring water underneath washer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the areas for the motor and pump and the Agitator Basket and Tub .
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer model 70 leaking
More than likely the pump. Very easy fix. To keep from being redundant I prepared a page on direct drive coupling removal and replacement. The pump must be removed to fix this item therefore it pertains to your problem. Plus you can watch for leaks better with the cabinet removed. To read click HERE.
Jan 18, 2009 | Kenmore 22422 Top Load Washer
Series 70 Kenmore will not spin on any cycle.
Since the washer would still pump out the water, I removed the cover, then the pump, then the motor and I then found the coupler was broken.
Jan 09, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
188 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
