Question about Canon BubbleJet i70 InkJet Photo Printer
My printer starts to print, then stops and gives the error number 5100. the instructions ask me to turn the printer off and then back on again. this does not work. What is error code 5100?
  • 426 Answers
This is a problem that can happen when using a non genuine print cartridge check if that could be the problem
Posted on Jul 15, 2009
When I try to print I get the following message: "Error Number: 5100 A Problem has occurred with the printer mechanism. Cancel printing and turn off the printer. Wait a few moments, then turn the power...
Did you follow the "cancel...." instructions?
Did the problem persist?
Did you contact your local CANON office, and ask for the location of the nearest authorized CANON Service Centre?
If so, what did they say?
Is your printer still under warranty?
Have you exercised the warranty, to get it repaired/replaced?
Sep 01, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Error message after copying 5100
This error takes place when a encoder sensor is dirty on a back side print head.
Jun 21, 2010 | Canon Pixma MP480 All-In-One InkJet...
Service error 5100 on canon prixma mp198
Service Error 5100
Cause : Movement of the Print Head Holder is blocked.
Action "Clear the paper jam or foreign object that is preventing the Print Hed Holder from moving, cancel printing from your computer, then turn off the machine and turn it back on again.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 06, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100
Google service error 5100 you need to download the free epson counter resetter, once downloaded install choose your model number & it gives you the choice to reset the counters, do that & you will be printing again.
Nov 08, 2009 | Canon i860 InkJet Photo Printer
Error 5100 in Canon MP160
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Apr 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Soon after initiating printing, Canon s400 printer stops with a loud clunk. This produces Error 5100. Turning off and on again does not help.
Hi You can Try
Error Code 5100 This happens lots in caon
Solution 1:
Solution 2:
Apr 13, 2009 | Canon S400 InkJet Printer
I have error code with my MP460 canon
1.First I recommend, resetting your printer. Turn it off and unplug it. Wait at least 10 seconds, plug it back in, and turn it on.
2. Next, if you feel comfortable trying to fix the printer on your own, you can follow these instructions after the phone number. If not, I recommend calling Canon and asking them to repair it for you. You can reach Canon support by calling 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).:
I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on)
Jan 09, 2009 | Canon PIXMA MP460 All-In-One InkJet...
How to correct error 5100 in canon pixima ip 1800 prnter
Hi You can Try
If you still look at this web then have a go
Error Code 5100
Solution 1:
Solution 2:
Sep 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Service error 5100
Hello it only a try but could be
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Jul 28, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Canon BubbleJet i70 InkJet Photo Printer Logo
512 people viewed this question
old marine
old marine
