Question about Kenmore 22422 Top Load Washer
Kenmore Series 70 won't spin
I have a Kenmore series 70 (Model 11020712990). Everything works fine (fill, agitate, rinse and pump out) except that it won't spin out the clothes. I have verified that the switch on the door is OK and the motor is running. If I give it a little help by hand the drum will spin on it's own but not up to full speed. I suspect that the clutch is slipping but I want to confirm before I purchase and install a new clutch.
Thanks,
Scott
    President:
  • 942 Answers
Hi..
In that case you need to check the other parts which is faulty already, try to check this parts first
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
If there is a parts which is faulty already,you need to replace it, so that it can work properly.
Hope it may helpful for you !!!
Regards
PCmania
Posted on Jul 15, 2009
  • 52 Answers
Sounds more like a transmission or a spin tube problem
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series model #11020712990 won't rinse
The TIMER is what is bad in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Kenmore 20172 Top Load Washer
Kenmore series 70 model 24732
check the lid switch. that is the most common problem if not spinning.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore 24732 Top Load Washer
Kenmore 22422 Top Load Washer Logo
500 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
