And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
this error is: DST Log contains previous error(s). Its an HDD error. You can try to unplug and replug HDD if this dont help call dell they will exchange your HDD if its still on guaranty.
Re: windows Vista will not start
I had the same problem and came across this solution that worked for me as well:
18 Aug 2009 07:28PM
I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
You would first need to make sure Windows does not restart automatically when a blue screen error appears. Then you can analyze the problem and fix the cause.
