Question about Dometic Rooftop RV Air Conditioner
Correction to my original problem
I have a duro therm rv air conditioner and when it runs it runs great. The problem I am having is that when the unit reaches the right temperature, the a/c stops working but continues to have a humming sound which I have to shut off with the breaker. I have replaced the contoller unit but to no avail. What else could it be? Joe Keegin
  • 534 Answers
Sounds to me like your contactor switch is not fully disengaging when unit shuts off. The reason I think this is even though the unit itself shuts off there is still power going to the contactor but, once you shut power off to contactor by shutting off breaker you release contactor since there isnt any power left to cause switch to continue to be energized.
Posted on Jul 15, 2009
Why does my Duro-Therm by dometic roof top air conditioner make extra chatter noise on high speed but not on low speed?
clen fan blades at both end of motor. the temperture will be colder at lower fan speed. depending on age and useage the bearings might be going out in motor.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
Duro therm , penguin 2 1988 model
ADDING FREON IS A LITTLE MORE COMPLEX AND BEST LEFT TO A PRO, YOU CAN MAKE SURE THE FAN IS OILED AND THAT THE FINS ARE CLEAN, TAKE NOTE IF YOU SEE A OILY SPOT ON THE UNIT THIS MAY BE THE SIGN OF A FREON LEAK ,, IT MIGHT BE WELDED AND RECHARGED .. THATS MORE BETTER THAN BUYING A NEW UNIT CUZ THESE AINT CHEAP ! JAY THE POOL PUMP GUY IN LONGWOOD FL
Feb 02, 2012 | Dometic Rooftop RV Air Conditioner
My duro therm 15000 btu air conditioner runs fine until set temp is reached. The unit then starts to cycle on and off about every 2 minutes.
Service your indoor and out door. Due to over dusty, sometimes, this type of malfunction may happen. Thanks.
Oct 16, 2011 | Dometic Rooftop RV Air Conditioner
Change starter capacitor ac work work
What about furnace is it working at all?
Aug 02, 2009 | Dometic Rooftop RV Air Conditioner
Duro Therm. AC fan comes on but compressor takes 5 min. before
Compressor may have five minute time delay for compressor protection. Russ
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Duro-therm rv roof a/c..model 57915.331...compressor coming on..fan not running..after a couple min. breaker trips....fan will not run on manual or auto...help,blackie williamson
Either your fan is stuck due to age or grime or is shot
if the fan does not provide cooling then the unit goes into thermal protection mode and shuts down
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
Duro Therm air conditioner
Most likley this is caused by a pressure switch dropping out then making again after the pressure drops off. Try cleaning your coil on the outside on the roof as most likley it is a high pressure switch causing this problem.
Jun 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
136 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
