if your cameras power supply is connected, ON" the unit connect a B N C to the video out point, the other end connect with the monitors video point.
The problem you are experiencing is caused by a bad LCD flex cable and can be repaired fairly inexpensively. However, Ti's not really a user serviceable problem and will need to be repaired by a qualified technician.
For more information about this, please click HERE
The camcorder has an extirely separate storage compartments functioning as an entity of its own. Capture the pictures or videos to be stored on the cameras builtin hard disk. Once the shoots acquired are ready to be transmitted into the computer require USB cables provided with the camera at acquisition. An unavailble USb cable is acquirable from retail to achieve the link for transfer to take place. Plugging the camera to the computer with cables provided should produce transfer results. The computer always request to transfer what has been acquire in the cameras disk. A permittion response usually a click of button would require naming the photos or videos about to be imported into the computer. provide a name to the transfer media and also choose from the pop up menu automatically displayed an area on the computer. For example, the computers pictures or briefcase allows to store similar files easily retrievable with computers that have several data files or disk storage media.
To save the video on a computer, a firewire connections must first be established from the JVC GR-DX307 AS to the appropriate firewire port of the laptop (assuming it has one or through a PCMCIA firewire adapter card if required). In the camera, the FireWire/DV port is located beneath the mode dial on the left side of the JVC GR-DX307’s body. To access the FireWire/DV port, the LCD monitor must be first opened.
Soon as that connection is established, you can use Windows Import Video (Vista) to capture / download the videos.
Alternately, the A / V port of the camera maybe used to connect to a DVD Recorder for direct, realtime copying & burning. For the disc to be playable in another machine, it must be finalized.
Symptoms in your JVC GR-D90US shows problem with CCD Imager IC and this part needs to replace.
JVC has Free of Cost repair scheme for subject model camera having same problem. Isn't good news?
Click JVC Support for details how to get free service.
Regards,
Please locate RESET push button in camera (its tinny button pushed by ballpen) and perform reset.
2nd possibility is broken ribbon wire connecting lcd and main board of camera. in this case you need qualified technician or JVC service center.
Fist of all I like to inform in computer S-Video output of the camera usually does not fit to computer. Only if the computer has S-Video Input card it will be possible. However logic is simple. Digital Camera or Camcorders uses 1394 or USB connection to connect to the computer. You havent indicate what model of JVC you use, almost all JVC Digital Cameras come with USB connection option. All you need to put USB cable in between. If it asks driver, use the CD comes with the Camera or download from JVC's support website. http://support.jvc.com/
