Question about AOpen AX45-V (91.88I10.004) Motherboard
I have an ax45-v that wont boot past ram check..ram check says ok but than comp freezes
  • bl1sk Jul 15, 2009
    Tried to clean to ram/ram banks, no go when its booting up the ram passes the check(256mb.....ok) but than the comp freezes when it should be trying to boot from cd/hd, cant load bios or boot settings, Sometimes it had 1 long 3 second beep
    Sergeant:
  • 175 Answers
Change ram bank, clean your ram, try to load windows by pressing F8 key and then in Safe Mode.
Regards;
Hassan
Posted on Jul 15, 2009
Do you know what the max memory supported on the AOpen AX45-4D motherboard? Thanks!
From what I can remember the motherboard supports 2GB of ram (1x1GB in each slot).
Regards.
Jan 07, 2011 | AOpen AX45-4D Max Motherboard
Sony Vaio VGN-SZ460N - freezes on System Recovery
I put my money on that you have a CPU over temperature problem, and/or intermittent RAM problem.
Be sure you are ESD safe when working on the electronics as follow !
I suggest, using a eye piece magnifier and a wooden tooth pick and carefully touch each pin of your RAM sockets and see if the soldering is bad, allowing the pin to move slightly. If that happens, well it needs re-soldering there, make sure you use leaded solder, not the ROHS crapp.
If that turns out to be ok, then check your processor. It might over heat.
You may want to observe if the CPU fans runs at all and if it runs at full speed most the time, even if you don't run any 'heavy' programs. This usually would indicate poor heat dissipation. Most Sony Laptops have a piece of thermal foam pad is used for heat transfer from the CPU chip into the heat sink. Over time this pad shrinks, effectively impeding the heat transfer causing the CPU to over heat and intermittent shutdowns ect. I suggest, find a new piece of thermal pad or replace that with a piece of copper sheet material and use Thermalloy transfer paste.
Jul 14, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Installed new ram-went from 2 512 sticks to 2 1g sticks, the comp wont boot, only the fans come on, no lights on the power button or signal to the monitor. I put the old ram back in to see if it would...
dose the ram have mem chips on both sides of the ram stick, sometimes this causes the problems, i would sugest that you clear the Cmos, maybe take out the bios batterie and leave it unplugged for couple of hours, plug it back in and see if the old ram works ok, if it dose then maybe try the new ram maybe one stick at first.
good luck.
Apr 02, 2009 | AOpen XC Cube EX661L (95EZ619321) Barebone
Boot up
ok from the symptoms you are describing your issue is low ram. If when you finally get it to boot up go to the start menu and right click on Computer or my computer. Then go to properties and tell me what the ram size is. If it is 512 mb or lower you need to increase the ram size. If this is so let me know and I will help you from there. Take care .. Mark
Jun 28, 2008 | Computers & Internet
My Acer T180 wont boot! =.(...
This sounds potentially like a failing memory stick. From another computer download and burn Memtest to a CD and try booting from it to test your RAM.
May 13, 2008 | Acer Aspire™ T180 PC Desktop
P4 comp not booting up
get working processor like that of your son's system and working ram, remove both the processor and ram on the system and substitute with the new ones and try booting.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 14, 2008 | ASUS P4B266 Motherboard
Help pc problems???
CHANGE THE POWER SUPPLAY.. BUT FIRTH..
1-UNPLUG HD AND TEST WITH FLOPPY OR CD BOOT DISK
2-UNPLUG YOUR MEDIA ROOM LIKE CD OR DVD AND TEST ONLY WITH FLOPPY BOOT DISK
3-UNPLUG VIDEO CARD AND ALL CARD ON YOUR MOTHERBOARD.. TEST ONLY WITH THE FLOPPY DISK AND ONBOARD VGA.. OR GOOD TESTED VGA CARD.
EXCUSE MY BAD ENGLISH.
CO3OV
CUBA
VICTORES45@YAHOO.ES
Oct 14, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Motherboard problem
if you have tried resetting the bios by putting the jumper across pins 2-3, then back to pins 1-2 and it still wont boot into the bios and you know the memory is ok, then the bios chip on the motherboard is damaged and may not be easy to replace as the board is quite old.
Aug 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Add-on
Hi im Joan Hall.I have a suggestion.Please check your IDE Cables.When u reboot your computer it should say detecting IDE Cables.If it beeps that usally means that your computer has an error.See if its not the IDE Cables because they will cause your computer to beep and not boot up right.
Dec 10, 2006 | Compaq Presario s4020wm (DK214AR#ABA) PC...
AOpen AX45-V (91.88I10.004) Motherboard Logo
77 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
