Question about Lite On Beige&Black16X Double Layer DVD RW CD-RW DVD Writer (SHW-160P6S) (DVDLO160P6S) Burner
Light_On dvdrw SHW-160p6s working properly but doesn't read anyth
Device manager say's it's working properly, but when I try to put in any kind of disk it doesn't read it or even spin, the light stays off. I've tried uninstalling it and restarting my computer to re-install it but nothing. It started out with just not being able to read dvds. But now nothing.
Light-On dvdrw SHW-160P6S
  • 696 Answers
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
I have a problem w/ my Lite On SHW-160P6S DVD RW Dual Layer Burner which won't read any DVD or CD. Also, The door to the unit won't open unless you insert a pin in the little hole on the front of the unit...
You will have to open the unit. To be honest, it's a good idea to buy a new one as I had to change to belt and my drive started smoking when I turned my computer on.
Dec 15, 2010 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
What is the comparable drive for lite-on dvdrw drive SHW-160P6S?
IMHO this Lite-On model,
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4893211&csid=_21
Except it is faster, will read, and burn dual layer disks, and also has LightScribe Technology.
(LightScribe Technology is from HP. You have to use HP disks, (CD or DVD) that are made for LightScribe Technology)
This is the specifications of the Lite-On SHW-160P6S for you to compare against,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1740403&CatId=482
This is information about HP's LightScribe Technology,
http://en.wikipedia.org/wiki/LightScribe
Regards,
joecoolvette
Nov 09, 2010 | Computers & Internet
Says I dont have a dvd burner and I have this one installed.. lite-on DVDRW SHW-160P6S..I can't burn a cd...any help? Sorry for the dumb question you guys!
do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
Nov 23, 2009 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
How can i get free software for my dvdrw recordrer
The dive has to be vista compatable Where did you get the driver?
Aug 02, 2009 | Computers & Internet
Error Message 'F:\ setup.exe is not a valid win32 application'
I uninstalled nitro. nitro for some reason blocks dvd roms from loading, and give a win 32 mesg.
Mar 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
LITE-ON DVDRW SHW-160P65
If windows sees the drive in device manager you can attempt to update the firmware. To access device manager, right click on My Computer and then go to properties. Then click the Hardware tab and then the Device Manager button. Look under DVD/CD-Rom Drives and see if it's listed. If it is, then get the model information off the the drive. Sometimes it is listed in Device Manger, sometimes not, you may have to take the drive out of the PC. After you get the info, post it here and I can point you in the right direction of a firmware update.
Jul 21, 2008 | Acer Aspire SA20 PC Desktop
Problem with LITE-ON DVDRW SHW-160P6S ATA Device
There is a whole bunch of helpful stuff at http://www.tomshardware.com/forum/196090-32-lite-dvdrw-160p6s-burning-problems
Seems that the drive may overheat, and will need replacement if in warranty. Some advice given: get another type drive. Also, check the device manager and make sure it's running in DMA mode and not PIO mode. If you have an nForceX mobo and using the SW IDE driver, reinstall with the normal IDE driver and try again. In device manager, check under IDE ATA/ATAPI controllers. Right-click and select properties on the IDE Channel your DVD recorder is attached to. Transfer mode should be set to "DMA if available". Current transfer mode should be "Ultra DMA Mode 4". If it says Mode 2: Your drive may be experiencing problems which are causing windows to drop its speed. There is a support article with a fix. To surmize:
After the Windows IDE/ATAPI Port driver (Atapi.sys) receives a cumulative total of six time-out or cyclical redundancy check (CRC) errors, the driver reduces the communications speed (the transfer mode) from the highest Direct Memory Access (DMA) mode to lower DMA modes in steps. If the driver continues to receive time-out or CRC errors, the driver eventually reduces the transfer mode to the slowest mode (PIO mode).
If you have dropped from DMA mode 4 to DMA mode 2, and you have a spare ribbon cable, you may want to try swapping it out. Also, if there is another device on the same channel as the DVD drive, try disconnecting it.
Mar 12, 2008 | Computers & Internet
If your DVD/CDROM is not working ie..playing movies or not installing programs it may be becuase you have installed a software program that edited the regitry for the DVD/CDROM - (Limewire, any burning software, etc..) windwos installs an Upperfilter and or a Lowerfilter in the registry for the CDROM - to correct this follow these instructions:
To resolve this problem, remove the affected filter drivers.
To do this, follow these steps:
1. Click Start, type regedit in the Start Search box (Vista) or regedit in the Run box (XP), and then click Regedit in the
Programs list if in Vista or click Open in XP.
If you are prompted for an administrator password or confirmation, type your password, or click Continue. (Vista)
2. Locate, and then click the following registry subkeys: (must be exact keys)
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Once you have clciked Class the click Edit on the menu at the top
Copy and paste the following key including the curly braces into the Find What box.
Click "Find Next"
{4D36E965-E325-11CE-BFC1-08002BE10318}
3. Highlight by clicking on "UpperFilter" and "LowerFilter" ONLY - then hit Delete on the keyboard and select Yes
4. Shutdown and restart the computer
Jan 25, 2008 | Computers & Internet
Computers & Internet Logo
245 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
