Question about SDI iHome iH4 Battery for Apple iPod
Volume control not working for IH4, stuck on one setting, IPOD or remote or volume buttons on radio has no affect on volume.
Should I repair my adcom GTP-506?
It sounds as though a remote control button is stuck or perhaps one of the remote control sensors within the unit itself. I would imagine this piece of equipment to be well worth repairing and likely the most cost effective avenue as well.
Jul 28, 2014 | Adcom Audio Players & Recorders
Volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Wake up with the radio is always set to level 19... I would like to set my radio alarm with a lower volume... my centrios is a Speed to Sound CENTRIOS IPOD/IPHONE CLOCK RADIO I will return this
We also have this problem. Found this info in the product's Q&A on the website: http://answers.thesource.ca/answers/9026/product/1218694/centrios-centrios-ipod-iphone-clock-radio-white-questions-answers/questions.htm
"Ok. there is a way that you can LOWER the wakeup radio volume. turn on the radio (forget about the alarm right now) and go to the station that you want. when you get to the station, you should be able to press the 'skip/fast forward' button on the remote. when you do this, number 5 should show up beside the station #. When you do this, it lowers the overall volume of every volume level, so now level 19 is equal to volume level 9/10, which for me is loud enough to wake me, but not give me a heart attack! so, now when the alarm goes of, the volume is a lot lower. BUT if you want to wake up to your ipod, this method will NOT work, it will still be up at level 19. so when you turn on your ipod, it will be really LOUD. again, this only works with the radio."
Also if you are waking to ipod and not radio this was in the reviews:
"Fooled with it for a bit and discovered that you have to turn down the volume of the iPod first before putting it on the dock. We've tried it a few times just to make sure and it worked every time!!"
Still not a perfect solution, but a great improvement. Hope this helps someone.
Jan 08, 2011 | Centrios Classic Flip Clock
How do i get the radio to work
Besides playing your favorite songs and custom playlists, you can also listen to your favorite DJs and talk shows on your iPod Nano by using it as a radio.
The iPod Radio Remote is a small and convenient accessory that lets you tune in to live radio when you're on the go, and also allows you to remotely control your iPod. Here is how you can easily setup Radio Remote on your iPod Nano and start using it as a radio.
  1. Connect the ipod Radio Remote to your iPod Nano by plugging it into the dock connector. Plug your headphones into the port at the top of the Radio Remote, next to the hold switch.
  2. Once the Radio Remote is connected, select "Music" and then "Radio" on your iPod. The Radio Remote will automatically tune in to the first available station it finds. The iPod screen will show the radio station and any other available information or data.
  3. Press the center button on the iPod. Use your iPod click wheel to find other stations. Once you have found your favorite station, hold the "Center" button down until a triangle appears on the radio dialer on your iPod screen.
  4. Once you have set up all of your favorite radio stations, use the "Next/Fast-Forward" or "Previous/Rewind" buttons to navigate between them.
Good luck.
Apr 28, 2010 | Apple iPod nano
The volume control on my new iPod Nano isn't working
The iPod Nano has the ability to "lock" the volume of music played at a particular level. Perhaps this only affects the volume of the earphones (versus the internal speaker). Please see "Setting The Maximum Volume Limit" in the user's manual:
http://manuals.info.apple.com/en/ipod_nano_features_guide.pdf
Feb 18, 2010 | Audio Players & Recorders
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
ISymphony CRDCD clock radio alarm programming
Play around with the Alarm1 button, test it every minute and when it goes off press Alarm1 again to stop it, not snooze. Then try pressing vol + as nothing is playing. Keep trying until your alarm goes off at the desired volume that you put in your Alarm1 settings
Mar 07, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
TDK icubic controls not controlling ipod
my icubic is stuck on a radio station which says mw then the station then khz
i dont no how to change it back to i can listen to fm radio. can u plzz help me!!
Jun 01, 2008 | Audio Players & Recorders
DVD Menu & Volume Control
i recommend getting a beafier remote some where in the 20 to 30 dollar range i owned one of these and they just sucked in codes and overall functionality i gave it to my dog went out next day bought a beafy remote
radio shack is not always up to speed on there equipment and sometimes outdated and a 7.99 uni. remote doesnt do it for me i think you can tell that by just being here on site asking for help
the remote bites
Apr 24, 2008 | Radio Shack (15-2147) Remote Control
SDI iHome iH4 Battery for Apple iPod Logo
309 people viewed this question
Top SDI Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SDI Audio Player and Recorder Expert? Answer questions, earn points and help others
