When i start my machine it appear this message: "Turn off, PCU CYAN ERROR, Install correctly. I have all ready done that, but stills appearing. A few days ago, my printer had this error message: ERROR SC682-223 This error messages are related ? Thanks
SOURCE: Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
SOURCE: I have a Ricoh SP
You might take the cartridges out and shake them to redistribute the toner, and see if that helps.
This answer from another tech on FixYa might help:
http://www.fixya.com/support/t307479-really_replace_photoconductor_unit
This web blog might be of interest to you and help:
http://www.copytechnet.com/forums/ricoh/15431-set-magenta-pcu-correctly-error.html
As a last resort, here's Ricoh's support site:
http://www.ricoh-usa.com/
Good luck, and hope this helps.
SOURCE: How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
