Question about Ovens
A loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
I have a Lincoln 1456 impinger pizza gas oven. I get a loud buzzing noise when the oven fires.The noise disappears when the oven cuts out but comes back when it fires up again
  • Anonymous Mar 30, 2014
    Combustion blower motor missing damper plate
This sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Posted on Aug 21, 2009
  • reggio72 Apr 21, 2011
    My 1456 had the same problem, the main fan had a crack on one of the fan blades, which was causing the oven to vibrate and the cracked part was touching the surround. It started with a buzzing noise but then got louder and louder as the crack got bigger especially when it would fire up.
    $1680.00 later it is quieter than my 1006.
  • 106 Answers
This occars due to failed start in firering up. usually the main cause is low oven presure. meaning oven pressure switch could have failed.
Open the control panel couver and find the black oven presure switch with three wires and a small presure tube. make sure its hanging freely in a horizontal way and make sure the tube attached to it is unblocked.
Posted on Jul 29, 2014
I have a remanufactured lincoln impinger 1000 gas conveyor pizza oven which I believe was converted to a fast bake 1450 model and the main fan motor on the back is screaming.
If the main fan motor is screaming in your lincoln impinger oven, actually that means the motor is faulty. more so the bearing in the motor are worn out and should be replaced, its easier to replace the motor itself but the motor is very expensive. To save money you can actually replace the bearings your self by opening the back cover in which the motor is mounted, then unmount the motor and disassemble it so you can take out the bearings. take the bearings as a sample to a bearing store so that you can get the size correct.
make sure you get bearings that can handle high temperatures and not those with plastic seals ment for wet or water places.
Apr 29, 2014 | Lincoln Ovens
Hi i 'm looking for lincoln impinger 1456
Google search "Lincoln impinge" and find your local service agent.
Oct 17, 2013 | Lincoln Ovens
Pizza not getting crispy on bottom
Clean the fingers and call in the morning
Sep 11, 2013 | Lincoln Impinger 1116 Gas Oven
I have a Lincoln Impinger pizza oven that won't
Yes, it could be, because the heating element is OK
Mar 22, 2013 | Ovens
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Apr 29, 2011 | Lincoln 1132000U - Impringer II Express...
I got a 1301 208v the fan blows good but it does
If threre is no alarm please make sure that the gas inlet pressure is ok or contact me at maugoro@yahoo.com
Feb 05, 2010 | Lincoln Ovens
Gas conversion kit
If the manufacturer can't or won't supply one, check with your local LP gas supplier, if they dont do this type of service they can likely refer you to someone who can, This is not a typical "do it yourself" type project, if its to be used in a commercial application, an unapproved conversion may render the oven unsafe to operate causing a structure fire and bringing down the wrath of your local fire martial.
Aug 15, 2009 | Lincoln Conveyor Oven - 1133-000-A
Ovens Logo
637 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
