Question about Dewalt Garden
DP3750 / 4GPM - Pump oil was milky. Drained, washed out & refilled w/ pump oil. No pressure and spewing water out the soap siphon inlet.
    Problem Solver:
  • 5 Answers
Thats the water in the oil! it means that gasket dos not hold the preshe.
Posted on Jul 15, 2009
How ofte I have tochange the water pump oil
every time it gets corrupted with water , it will turn from golden/clear to gold/milky when its time to replace it
an allways ck your oil level in pump and engine an refill if needed when adding gas to tank , its natural to be missing some each time as equipment gets older an older
Nov 07, 2015 | Dewalt Pressure Washer. 4200 PSI 4.0 GPM...
How do i prime my troy built 2550 psi pump for the soap?
You have to use a low pressure nozzle ( usually black with very large spray opening) With the low pressure nozzle siphons your detergent in with the spray water . If you are using a high pressure nozzle the soap will not prime.
Oct 26, 2014 | Garden
I have a Honda pressure washer with Cat Pump 3dx29gsi, it runs rough when I pull the trigger and after 5 min of running, oil starts to spit out of small hole on red fill cap on pump
Sounds like you need to open the pump and inspect the pistons and seals. It appears that the seals & or pistons are worn and the water is by passing into the crankcase of the gear box. A sure sign oil coming out of the filler cap & the oil in the gear box will look milky ( water & oil mixed) This is not a difficult task to perform. You can purchase seal kits on line or in your area from suppliers of multi brand pressure washers who usually stock plenty of spare parts for various brands; many of which are interchangable. if you buy from a brand specific supplier you will pay much, much more. I suggest you remove the pump and dismantle it, inspect the parts to determine what parts are required and take it from there . If you are not experienced in doing mechanical repairs use your camera / Phone and snap each step as you dismantle the pump. First Remove the complete pump from the engine and then remove the pump head from the gear box - about 6 bolts and a few fittings . In the head there are several check valves ( usually 3 inlet & 3 outlet) these need to be removed to be cleaned, inspected, check o-rings, springs and valve seat ( usually a small metal disc ) which in many cases is the cause of low pressure due to dirt lodged between the disc & seat. Remove one at a time note how they are assembled, take a photo and place in a small zip-loc bag each one individually & mark the bag in relation to where each one was removed.
The same goes for the seals and washers on the pistons, these are located in the housing and depending on the brand are stacked according to the design of the seals , again take photos , tag & bag them. I suggest to tie each set together exactly as they were assembled when you removed them; it will make it a lot easier for you to assemble them correctly when the time comes to install them. Finally clean out the crankcase to remove the milky oil & water mixture.
Go for it Its not rocket sicence.
Jun 03, 2012 | Caterpillar CAT Pump Pressure Washer Pump...
When I wash clothes it keeps beeping and has a flashing F H... what does this mean?
It means that the machine doesn't detect enough water entering or your pressure switch could be going bad.
Potential Causes
If there is no water in the unit: • Make sure that both valves at the water source(s) are turned on all the way. • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves • Verify inlet valve operation
If there is water in the unit: • Verify Drain pump operation • Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch • Verify there is not a siphon problem • Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU) • Check all hoses for possible leaks • Verify pressure switch operation • Verify flow meter operation • Verify CCU operation
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F20 error code ? What to do ?
F20 ERROR CODE NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
The pressure switch is not tripped after 6 minutes.
Possible Causes/Procedure ? If there is no water in the unit: - Make sure that both valves at the water source(s) are turned on all the way. - Check for plugged or kinked inlet hoses or plugged screens in the inlet valves. - Verify inlet valve operation. ? If there is water in the unit: - Verify drain pump operation. - Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch. 1. Verify there is not a siphon problem. 2. Press STOP twice to clear the display. The machine will drain for 3 minutes before unlocking the door. 3. Unplug washer or disconnect power. 4. Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU). 5. Check all hoses for possible leaks. 6. Plug in washer or reconnect power 7. Verify pressure switch operation. 8. Verify CCU operation by running a Diagnostic Test or any cycle.
Dec 27, 2010 | Kenmore HE2 Plus Front Load Washer
Oil milky white in pump
it may have a slow water leak inside the pump.
change oil and monitor the new oil.
if it goes milky the next time you use it then it has a bad leak and the seals will need to be
replaced,otherwise the bearings will rust & seize
Dec 18, 2010 | Honda Pressure Washer PSI 3000
FLASHING HF CODE WILL NOT WASH OR UNLOCK
Press PAUSE/CANCEL twice to clear the display.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
* Verify there is not a siphon problem
* Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
* Check all hoses for possible leaks
* Verify pressure switch operation
* Verify flow meter operation
* Verify CCU operation
Sep 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lg tromm wm2277hs stops when it gets to the rinse cycle...OE error code? washes, won't drain, won't rinse
hi
  • If there is no water in the unit:
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check pressure switch operation
  • Check flow meter operation
Jul 24, 2009 | LG Washing Machines
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Garden Logo
735 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
