Question about RTO PasLode 900420 Impulse Framing Nailer
Gun shoots once
The gun will shoot once then i have to wait for the fan to go off and open the back were the fuel goes then close it and the gun will shoot only one time agian. i have tore the gun down and cleaned everything but i still get the same results if any one knows how to fix this problem please reply.
So this is what i found and it worked for me.
If you have an impulse that is firing erratically, it is probably the switch mounted on the head of the toolthat plugs into the fan circuit board. I have both framers and trimmersthat have had this problem and would like to find a good source for theswitches. My oldest has been used almost daily since 1996 and thisswitch is the only problem I have had , keep your tool clean. hopethis helps......
Posted on Sep 12, 2009
  • 2,176 Answers
When you say cleaned did you replace the o rings? and lubricate them. on the framing nailer there are 2 push rods in the area where the fan is, are they in place and move freely, they push the door up where the fuel cell is to load fresh fuel, check these and the stem that is in the head is it in correctly with the open portion facing up? Check the expiration date on the fuel cell it is on the bottom, an out of date cell will give you fits also. When you depress the safety to fire and release it after the nail does it move freely or hang up. These are all thoughts that you might look for. Check them out and if you still have trouble give me the exact model number and other symptoms.
Posted on Aug 18, 2009
How do I shoot??
Point gun toward target and place finger on trigger. Pull trigger.
Feb 22, 2015 | Cars & Trucks
Nail gun wont shoot
When you say it turns on - I'm assuming you mean the fan runs when you depress the nose? If the fan does not run - the problem is most likely the head switch which is part of the circuit assy in this tool.http://paslode.com/uploadedFiles/CF325_Parts_Diagram_Schematics.pdf
Part # 22
If the fan runs but it doesn't shoot - first - Check your fuel! I have seen many times where someone forgot to activate the fuel before installing it. On the bottom of each cell is a date code stamp - if it is within date, press the nozzle of the cell against a solid surface (bench etc) and you should get a good burst of fuel - if not replace the fuel.
Lastly, If the tool is clean, the fan runs, and the fuel is good but it still won't fire it is one of 3 things: a bad spark plug / wire (uncommon), a bad trigger switch (which is also part of part #22 circuit assy), or a bad ESU (electronic spark unit).
If the basic things don't solve your problem, I would suggest bringing it to a qualified repair shop to diagnose because the parts are expensive to play duck duck goose with.
Feb 06, 2014 | BreatheAudio Paslode Impulse Cf325...
What are the best chokes to use for a beginner on clay pigeon shooting?
To increase your odds of hitting targets - use the most "open" choke that will maintain good density at the distance you're shooting - exactly the same as most experienced shooters do... Skeet choke for shooting Skeet, Mod to Full for Trap, Cyl to Light Mod will handle 95% of shots on the sporting clays courses around here.
To increase your skill - occasionally use your full choke for everything until you learn proper gun mount, swing, and lead and follow through. When you start getting frustrated, switch back to the open chokes to get a little positive feedback on some close targets, then move back to the full choke.
Jan 17, 2013 | Sport & Outdoor - Others
I bought a new mossberg 590 a1 shot gun a month ago, I love the gun but its having a couple of problems, the first problem is that when shooting every once in a while i get sprayed in the face with exuast...
Personally, with that many problems, I'd call Mossberg and get a return authorization. None of these things should be happening, especially with a new gun.
Feb 17, 2011 | Mossberg Sport & Outdoor - Others
After about an hour of play with the pulse r76 it will stop shooting and only make a distinctive click. I charge the battery, use my friends battery who has the same gun but the gun still wont shoot. Then...
If you charge the battery for more than five hours or over night, you'll burn out the battery. When your done playing with the gun dont put it on the charger immediatly as this will overheat the battery. Wait about an hour for the bettery to cool and then put it on the charger. It should work fine after that.
Feb 04, 2011 | Crosman (4032)
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
It has been so long since i used my spray gun i foregot what each knob is for
The knob on the left of the gun is your fan adjustment. turn it back towards you and it will shoot a stream of paint, turn it forward and it will shoot in a fan patter. The knob at the bottom by the air inlet is your air pressure adjustment. The knob on the back is to remove the needle and spring.
Cheers!
Feb 23, 2010 | RTO Central Pneumatic Gravity Feed Spray...
Guns green light comes on fan comes on but gun doesn't shoot has plenty of fuel in canister
ther is a depth adgustment on the front of the gun,try lowering the adjustment tip a little at a time.see if that works.
May 18, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I can't arm my rifle 66 powermaster
there is a slot that says open open it and put bbs in.. close it ther is a switch on top pull it back... turn the gun upside down and shake it... push the button up... pump 3-15 times and pull back bolt... and push forward thenturn safety off and shoot
Apr 07, 2009 | BSA Air Gun Scopes
RTO PasLode 900420 Impulse Framing Nailer  Logo
227 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
