Question about Gateway 830GM PC Desktop
Gateway 830GM power
I always had problems with my machine every now and again. It would just freeze up and the light would stay on solid. I couldn't hit control alt delete or anything. Seemed like hardware because I never had/found any viruses. Had to always shut off manually.
Recently it just won't turn on and power light isn't on in back of computer even when cord is plugged in. I popped it open and went through each cord coming from power supply and would try and get power light on back of computer to come on. It came on for everything except when I plugged back in cord going to mother board (master). Is this a mother board problem or power supply?
  • 2,418 Answers
Could be power supply, unplug every thing from the board, remove all drives, cards everything but the mem. turn it on, if you get some beeps, add your Hard drive. The power supply may not have the guts it take to run all the peripherals it used to, this test will tell you if its the board or power supply.
Posted on Jul 15, 2009
No sound on speakers except on itunes
I cannot find drivers on the Gateway Support site, which usually means the machine is no longer supported, which also usually means the Operating System is no longer supported. If this machine is running XP, or earlier, beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine, or don't try to get on the Internet with this one.
Jun 24, 2014 | Gateway 830GM PC Desktop
I have an 830GM and am suspicious of a hard drive crash or a motherboard failure and was wondering how to diagnose?
try replacing or swapping the hard drive with another machine and see if it happens again and on which machine if both machine's crash both MB and HD could be bad, If your machine with different HD works fine then it most likely was the HD If not then the MB might be at fault
Jan 24, 2011 | Gateway 830GM PC Desktop
Need new motherboard for Gateway 830GM
Looks like you have a p4 478 socket with ddr memory bad luck they only make 478 boards with ddr2 memory now. And when ever the power supply is as old as the motherboard it should be replaced to. Here's the specs I found on your computer http://www.shopping.com/xPF-Gateway-830GM. You could always try your luck on ebay good luck.
Jul 11, 2009 | Gateway 830GM PC Desktop
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway 830GM won't turn on
it is an internal problem,your SMPS (Switch Mode Power Supply unit) is gone bad,only by changing SMPS..your computer will turn on for sure,, thank you, Plz rate me...
Jun 29, 2009 | Gateway 830GM PC Desktop
Gateway 830gm wont turn on
1 of 2, either there is a ON/OFF button on the back and it is turned off, or 2) you might had a surge and it hit the system, especially if it is connected to a phone jack (for dial up or DSL).
Jun 16, 2009 | Gateway 830GM PC Desktop
Ethernet driver for gateway 830gm
Insert computer serial number here to download the drivers.
Alternatively click driver download here: Gateway Support - 4659 Gateway 830GM
Click on the drivers, download them , then install them one by one.
Follow instructions from setup program.
Mar 04, 2009 | Gateway 830GM PC Desktop
Once again another problem with this computer the drivers
all the flagged drivers
right click and try to update
which drivers
then let me know what has happened
Feb 20, 2009 | Gateway 830GM PC Desktop
Motherboard wiring
cba3c97.jpgthis is the diagram for 103390 Intel (Augsburg) 915G
Jan 06, 2009 | Gateway 830GM PC Desktop
Gateway 830GM PC Desktop Logo
268 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
