How to replace a compaq presario 1255 cmos battery
It appears that my old laptop needs a new cmos battery. I called Best Buy and they say they have the battery. My question is how do I install it?
Thank you so much!
Debbie
  • 1 more comment
  • Debbie in PA Nov 17, 2007
    Would you know if the battery is soldered in on this model or if I can just pop it in once I find it?
    Just one more question and I think I'm ready to give it a try. I was told at Best Buy that I can't just take the CMOS (RTF) battery out and put the new one in without losing the settings - that I would have to "trick" the laptop into thinking that the battery has not been changed by sliding the new one over the old one. Is this correct? Right now the laptop is still running but very slowly - it hasn't completely died yet.
    Thank you!
  • Anonymous Jul 06, 2008
    I need to change the CMOS battery in my Pressario 1250
    I have dissasembled the case & removed the key board but see no sign of the battery -- can anyone tell me the location and which component next to remove . I can see the big AMD - K6 processor center top.
    mgr
    Sniper:
  • 59 Answers
You have to take the case apart and find the old battery.It sounds like a large tast but you can pull it of in about 20 min.locate all the screws on the underside of the keyboard part of the laptop remove the main battery as ther may be a screw or 2 in the battery case once you are sure that you have removed all of the screws try seperating the 2 parts of the case sometimes they have clips that snap both parts together you can loosen then with a flathead if you find them by pressing inward and releasing them.once you have opened the case locate the battery and replace it .YOU CAN DO IT!
Posted on Nov 17, 2007
  • Brad
    Brad Nov 17, 2007
    It can be either, but I have been able to take them out even though they are soldered,just take a small flathead and carefully pry the top off the battery.Usually they are not soldered but being soldered shouldnt stop you.If you want to ..You can take a soldering gun and press it to the top of the peice of metal that the battery is soldered to,usually that isnt needed.Good Luck!
  • Brad
    Brad Nov 17, 2007
    If you have made custom settings in BIOS or any changes, they will be lost .But chances are if you havnt had any major upgrades, the BIOS will default to the original settings which will work just fine.Sometimes people have to alter the BIOS settings to install a second harddrive or a CD burner or other internal hardware upgrades.Also when people OVERCLOCK there CPU's these settings in BIOS are critical.When they change the battery they lose these settings and they have to reconfigure the cmos to their preffered settings.Unless you have mades specific changes in your BIOS then your safe.I have had to change several batteries and it always goes smooth.Also there is no special trick to swap the batteries.Im not sure why the gentleman at Best buy told you that you had to trick the Bios.when your computer boots up again I beleive it will ask you to cange the system time and date but after that your fine.One more thing,A dying CMOS battery will not cause your computer to slow down.Make sure your Anti virus is up to date and use spyware doctor to scan for any spyware.also try removing unused programs
After you have removed the keyboard and you are facing the processor, the CMOS is located under a small printed circuit board (PCB) to the left of the processor. This small PCB is fixed by two screws that you have to remove and it is also connected to the main board so don't be afraid to pull it up after the 2 screws are removed. The CMOS is a CR1220, 3V.
Posted on Sep 30, 2008
How do I remove/replace the hp compaq presario cq60-615DX internal battery. Not the CMOS one; the other large one at the back. There is no slider/lever. thanks
In order to remove the battery pack you should slide the Lock key to the Unlock position and keep it there until you have removed the battery. In the following video (at 00:08) you can see how to do it and replace the CMOS battery also. Hope that helps. How to replace the CMOS Battery in the Compaq Presario CQ60 Laptop
Here is the manual you can read more and see how to on page 46.
http://tim.id.au/laptops/hp/hp%20g60%20compaq%20presario%20cq60.pdf
Feb 18, 2014 | HP Compaq Presario V2000 Notebook
How can i change the CMOS battery of my Laptop Compaq Presario V2000?
Here is the location of the appropriate Service Manual - you will have to partially disassemble your computer to reach the battery and replace it.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Sep 19, 2012 | HP Compaq Presario 2200 Notebook
Before to start laptop appair the following error: 0270 real time clock error. save to disk file not found save to disk feature is disabled run phdisk for information.FILE:create new. ...
compaq is HP so best is to ask them, there, now here.
RTC error mean , the RTC coin cell is dead.
all PCs this old are dead battery ,
RTC= real time clock chip says IM DEAD, but is battery dead ,..
remove the coin cell, and put in a new one.
end story.
then set time .
best is to set time in BIOS setup. 1st.
this Compaq is 18 years old now. or 126 dog years.
id , push it off a cliff on the 4th July with fireworks. and all.
let me guess its XP the VIRUS magnet.
some this old are windows 98
a hopeless case there, no? no support, no books and no updates.
the books at HP are long gone
so now all books are , sold by horders. $$$
it can be costly and dangerous to deal with folks like that.
the book you lost , , the answer is on page 18
seen here
see coin, remove it and put in new one. end story.
https://www.manualslib.com/manual/30167/Compaq-Presario-Presario-1255.html?page=21#manual
Jun 27, 2017 | Compaq Presario 1255 Notebook
My computer clock is running fast... I figure it's the CMOS battery because it's almost 5 years old. It's a Compaq Presario SR1503WM Desktop. Which battery should I buy?
just u will remove the Cmos battery from your computers mother board and take it.
go to shop and ask like this battery i need.
then buy and replace it..
thank u sir... All The Best...
Apr 22, 2010 | HP Compaq Presario SR1503wm PC Desktop
Compaq Presario CQ60-215DX. Doesn't start
You will need to buy a new battery, there is no way old one will be OK. To see if it works, remove battery, and use wall adapter ONLY, PC should work fine. If not maybe Flat CMOS, replace, If replace and still NO go.must be bad motherboard (maybe try charge battery 5 hours left alone)
Mar 27, 2010 | Compaq CQ60-215DX Notebook
I need to find and replace the CMOS battery in a Compaq Presario 1200
write down the model number or the volt of your CMOS battery and go to any computer hardware shop..
buy the CMOS battery corresponding to your model number or your battery's volt...
all the CMOS battery are almost similar
Dec 19, 2009 | Compaq Presario 1200,1600 (297657-001)...
Compaq M2000 charges battery, but from batt or
The best sollution is to call your vendor for sollution, everything you can do to solve would void youe waranty
Jun 21, 2009 | Compaq Presario M2000 Notebook
I need to replace the CMOS battery in a Presario 906US Laptop
Here is service manual for Compaq Presario 900 (download parts one by one, then extract):
Part 1
Part 2
Part 3
Part 4
Mar 28, 2009 | HP Compaq Presario 906US Notebook
I've got a compaq presario 1245 laptop. On booting it gives me a black screen with "Error 0270 Real Time Clock Error" I can get into the Setup and boot screens (F1 & F10) but any changes (reset date/time...
hi
you will need to open your computer and look inside. if you are not sure take to a repair centre, the battery is on the motherboard, thats why you need to take really if you are going to be doing it. But i would advised to get a IT guy to do it for you. once its taken out you need to replace it with a new one.
Mar 25, 2009 | Compaq Presario 1275 Notebook
Computers & Internet Logo
2,829 people viewed this question
David Payne
David Payne
