Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
    Habit-Forming:
    New Friend:
  • 24 Answers
S Sigs is correct... however if the wires connecting your amplifier/Avr to your subwoofer ae not connecting properly, this might also happen. First check the connections.. then the capacitors.
Posted on Feb 20, 2016
    Master:
  • 406 Answers
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
klh powered subwoofer model ASW10-120B... when you - when-plug-in-power-makes-loud-buzzing-lgqxs5x4gp2eri5a2qchwtne-5-0.jpg
  • 6 Answers
Get a ground-loop isolator, it should get rid of the humming sound.
Posted on Jan 10, 2016
    Top Expert:
  • 9,098 Answers
Customer Reviews: KLH ASW10-120 Powered Subwoofer
www.amazon.com/KLH-ASW10-120-Subwoofer.../B...
Amazon.com, Inc.KLH ASW10-120 Powered Subwoofer (Discontinued by Manufacturer) .... It makes a loud humming noise even without anything hooked up to it, and the heat ... When the amp breaks down, you will also hear the hum much louder, >With no ... need a sub, but if going to crank it up buy something that can handle the power.
KLH making intermittent loud buzzing noise Speakers ...
www.fixya.com/tags/making...loud_buzzing_noise/...subwoofers/klh
KLH speakers & subwoofers making intermittent loud buzzing noise related questions... Question about ASW10-120 Subwoofer ... No function I have had this powered subwoofer for a few years and it worked well ... I then plugged in power cord and turned it on . ... KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz.
KLH constant noise Speakers & Subwoofers Questions ...
Posted on Jan 05, 2016
SOURCE:
KLH HPS 1100 powered subwoofer. as soon as plugged into AC we get a loud hum from spkr. had unit for 8yrs.
Hum usually indicates a power supply problem. If it has an internal supply you will need someone to check it's producing clean DC. Alternatively if you do open it (beware risk of shock!!) initially visually check condition of /replace any bulging electrolytic capacitors.
Jun 27, 2014 | Audio Players & Recorders
When I plug it up it makes a loud buzzing humming sound that's unconteollable with the volume.
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversable, try that. make sure all audio cables are pluh\gged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
If it still does it with no cables attached it's an internal amp problem.
Dec 31, 2010 | JBL PB10 Subwoofer
My subwoofer constantly makes a steady intermittent buzz sound while plugged in, even while powered off.
If it has a 3 prong plug, try a 3 prong adaptor - where only 2 prongs are plugged in. Sub's should not be grounded. If it still makes a hum noise, the amp circuitry may be compromised. Replace the amp with an equal at www.partsexpress.com
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Dec 06, 2010 | KLH PSW8100-8 Subwoofer
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Jan 31, 2010 | KLH ASW10-120 Subwoofer
KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Dec 26, 2009 | KLH ASW10-120 Subwoofer
Subwoofer problem
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your reciever feed at the entry point to your system.
Dec 23, 2009 | JVC RX-6018V Receiver
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
It is a klh powered subwoofer, which buzzes when plugged in, even though the power switch is set to "off"
Sounds like the grounds are screwed up. Try using a grounded wire for the subwoofer input. If that doesn't work, it sounds like something is internally screwed up, like the power supply doesn't fully power down. I guess besides buying a new amp, just connect it to a power strip where the switch is accesable and shut the sub off with the power supply.
Oct 10, 2009 | Audio Players & Recorders
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
867 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
