Question about Mtd 22" Yard Machine Push Mower
Does the mtd yard machine push mower have a throttle to adjust
  • 2,418 Answers
Most newer models do not have a throttle, but you can rev it up a bit, by finding the governor rod and spring and pulling it.
Posted on Jul 15, 2009
What's the valve gap set on a yard machine 139 ohv mtd push mower
3 to 5 thousandths of an inch on a cold engine.
Search Results
Lawn Mower Repair Valve Adjustment - YouTube
? 4:44
https://www.youtube.com/watch?v=NjzX-PUjKmo Mar 7, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on a Briggs OHV engine. The valves need to be ...
? 5:06
https://www.youtube.com/watch?v=j77Y5iwXTzg Mar 6, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on an overhead valve lawn mower engine. The valves ...
How to Adjust The Valves On An OHV Lawn Mower Engine ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers Sep 19, 2009 - How to Adjust The Valves On An OHV Lawn Mower Engine. By Lisa ... Many lawn mower engines use overhead valves. This means, the ... Turn the screwdriver to either increase or reduce the clearance between the setscrew and the top of the valve. Tighten ... Will Mothballs Keep Snakes Out of the Yard?
valve gap set on yard machine 139 ohv mtd push mower Google Search
Aug 14, 2017 | Mtd Garden
How to adjust the throttle
many newer mower have no adjustment
May 06, 2012 | Mtd 22" Yard Machine Push Mower
How much oil goes in a 22'' inch MTD yard machine push mower
Most normal push mowers require 20 ounces of engine oil. I recommend that you use only SAE 30 oil and try to use synthetic.
May 01, 2011 | Mtd 22" Yard Machine Push Mower
Idles fast all the time once you start it up...........just started doing this and is only one year old.......
Other than the throttle sticking there may be a couple things:
The idle screw is mal-adjusted.
There is an air leak where the carburetor meets the block.
The governor spring has bound or streched (depending on type) affecting the RPM.
Jul 29, 2010 | Mtd 22" Yard Machine Push Mower
Lost spring to carburetor mtd lawnmower
you can go down to any napa or hardware store and pick up a light small spring about 1/4 inch maby 2 to three inches long atach it to the throttle and your ready to go
Nov 08, 2009 | Mtd 22" Yard Machine Push Mower
How do I change the throttle cable on my yard machine lawnmower?
First thing you have to do is remove the little black box on the handle with a bolt going thru it. Once, this is done you'll see that the cable will only fit in there one way. Good luck
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
505 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
