Question about HP LaserJet 4L Printer
Black Streaks on Edges of Paper
Black streaks from toner on edges of paper when printing. About 1 inch wide on left, and just a trace on right.
Can this be fixed or is it time for new printer?
  • aikobooks Apr 19, 2009
    Normal 0 false false false MicrosoftInternetExplorer4
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Paper jammed and now printer prints black / gray lines verticallydown left side of paper. About 1 inch wide. printer is new . problem was caused because paper tray was over filled and large number of sheets were pulled into printer at once.
  • Anonymous Mar 12, 2014
    HP 4500 DN Black/grey streaks on paper, new black toner and transfer kit installed-Help!!!
  • HP Master
  • 1,113 Answers
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Posted on Nov 18, 2007
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
THE PAPER SELECT ARE NOT COMPATABLE, SELECT LGL IS EQUAL TO 8.5/14 FLSC IS EQUAL TO 8.5 /13. TRY TO SELECT BLACK COLOR OR CLEAN YOUR DEVELOPING UNIT.
Feb 06, 2014 | Canon imageCLASS D880 All-In-One Laser...
Vertical streaks
Or OPC is damaged, or there's something on it. If you want to see yourself DO NOT TOUCH ROLLER. To move it, try to push the gear. You need some power to do that. Stains can be removed from OPC with paper towel and isopropanol.
Jan 08, 2013 | HP Cb540a Cb541a Cb542a Cb543a...
Printing black
is the copy/print full black or have streaks or have dots, or ...
First, remove the toner crg., and check the drum surface if it has toner leftovers or spots or streaks, or... if so replace the toner crg.
btw. It also can be the fixing unit, but if these is the problem then the toner will not be "baked" on paper and it can be wide solid black stripe on corner.
Hope that helps!
Jan 10, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Getting streaks down left margin
I guess you have a problem in your fuser assembly
Mar 12, 2010 | HP LaserJet 1320 Printer
White bands on color photo prints
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
HP LaserJet 4L Printer Logo
570 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
