Question about Dell Inspiron 1420 Notebook
I was trying to replace Xp on my Inspiron with Win95 to run an old serial port plotter. Somehow I've managed to screw things up so that I can't access setup by hitting F2. The computer just goes to a blinking dash on the screen. Any idea? Thanks
  • stevekoester Jul 15, 2009
    Thanks for the quick response. I've tried all of the F2 variants.No luck. Where is the Battery?
    Thanks.
    Steve
  • 601 Answers
Hello stevekoester ,
You need to tap the F2 key 2-3 times as soon as you press the power button.
If still facing the same issue reset the BIOS and then try. take the BIOS battery out for 30min and then put it back to continue.
Let me know if you have any problem.
Thanks
Smith
Posted on Jul 15, 2009
Sound driver 1545 inspiron
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
be precise you might have to try a few times to get it right
hope this helps
Nov 16, 2012 | Microsoft Windows XP Professional for PC
Windows XP Boot Up
USB Keyboard take a while to register. Try a serial type keyboard if your system has the Purple serial port on the back.
May 25, 2012 | Dell Inspiron 531s Notebook
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
Both printer and 9 pin serial ports not working
What has changed? One solution is to go into BIOS when you first turn on your PC hit <del> key. Make sure the ports are enabled. The second solution is to make sure you didn't add a device with serial ports or something which is sharing the same IRQs, which is 3 4 and 7 traditionally (for COM1/2 and parallel port).
If you tried all this and it doesnt work, then somehow the chip on the motherboard which handles these (the UART chip) has broke, you need to replace the motherboard or buy a card with serial and parallel ports on it (this should be quite cheap, ie 10-20 dollars).
Nov 07, 2009 | Intel Computers & Internet
I have a Dell Inspiron 9200 running Windows XP pro. The other day I was running an external hard drive through a USB port...and since then...all my USB ports will not recognize ANY device. They run power...
A remedy would be buying a card that goes into a slot on this pc that has usb ports- giving that a shot will help you other then that the motherboard would need to be replaced at this point the cheap way out would be to just by a card- Thanks
Aug 07, 2009 | Dell Inspiron 9200 Notebook
Webcam not working
this might bcos of webcam driver try installaing again your driver.........as you have not mentioend this webcam is with serial port/ usb port........if any of them go to my computer right click.......go to hardware......go to device manager........go to usb go to universal serial bus converter & check for driver details is working or faulty............hope this will help you.............Sameeraryan
Dec 27, 2008 | Dell Inspiron 1525 Laptop Jet Black
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
Open Questions:
See all Dell Inspiron 1420 Notebook Questions
Dell Inspiron 1420 Notebook Logo
35 people viewed this question
Alun Cox
