Honda Civic Coupe Questions - car will not start. battery ok ...
www.cargurus.com > Questions > Honda > Civic Coupe
CarGurusJul 9, 2008 - Get someone to turn it over and see if it is getting spark. ... i have the same issue with my 1993 civic lx it has a 1.5 sohc non-vtec i changed ... comes wen the 2nd click of the main relay it doesn't occurs until after few minutes, few .... My 2000 Honda Civic Ex Vtec will not start, has a new tps, new throttle body, ...
Part 1 -How to Troubleshoot a No Start (1.6L Honda Civic)
troubleshootmyvehicle.com > Honda > 1.6L
Dec 31, 2012 - Difference Between a No Start and a No Crank Condition. ... can cause your 1.6L Honda Civic (Civic del Sol) to Crank but Not Start. ... In other words, the engine doesn't turn over at all. ... 1995, 1996, 1997, 1998, 1999, 2000.
98 Honda civic won't crank (PushStart) - YouTube
? 4:11
https://www.youtube.com/watch?v=X5W7OqjKB8I
Oct 21, 2013 - Uploaded by SkzDaniel
Honda Civic won't start or crank with the clutch but goes on when you push start it. ... 2000 Honda Civic LX with new battery and starter. Still will ...
? 6:34
https://www.youtube.com/watch?v=p7KAO__nM1s
Aug 21, 2013 - Uploaded by Robert SnyperMD
2000 Honda Civic LX with new battery and starter. Still will not start. ... Crank, No Start Diagnosis Honda Coil test. - Duration: 11:17. by ...
It only takes 10 to 20 amps to turn on lights and other accessories.
It takes around 180 to crank the engine over. You need to check out your battery for full charge and if it is very cold where you are your oil could be too thick to allow the engine to turn over.
SOURCE: P1457 - Honda Civic 2005 LX
this car come with tree diferent engines the answer i'm going to give you is for a 1.7 engine sohc that codes means you have a leak on the evaporative system this system monitor the vapors from fuel tank this code some time might appear for filling the fuel tank with car runing i recomend you to clear code and make sure the fuel cap is not loose because there is a fuel pressure sensor in the tank and if the sensor don't read the right pressure then it will set the code
SOURCE: 2003 Honda Civic -LX Timing belt
90000 Miles on the Timing Belt. Do not let this go! A timing belt failure can cause internal engine problems.
Should cost around 200 or so, depending upon your local labor rates.
Good Luck!
Brian
SOURCE: changing oxygen sensor for a 2000 honda civic lx
both are located in the exhaust system. You have to get the car off the ground and follw pipes. You cant miss the O2 sensors.
SOURCE: p 1705 code, honda civic lx 2001
Have tranny serviced . Check tranny fluid level fill with HONDA ONLY fluid. If not fixed have fluid drained and filter replaced on tranny
Testimonial: "thanks u very much. the problem has been resolved. very good advice."
SOURCE: 2003 honda civic how to remove door panel
Step one Look at the inside door handle. Behind it you should see a little cover, You pop that off and there will be 2 phillips head screws behind it. remove them.
Pop out the door handle, and unplug the power lock plug,
Youll also have to take the door lock rod, by spinning the plastic door handle 90 degrees until u can wiggle it out.
next remove the sail panel( The little triangle shaped piece in the corner of the door on the top, ( may have a tweeter in it) ( it just pops out)
Next take a screwdriver (flat head) and pry off the cover of the door handle, there will be
2 phillips head screw behind it ( remove screws)
Unplug power window connector (big green plug)
Now just start gently pry the door panel off with a screw driver, see if u can peek behind the panel and see where the panel clips are, and pry near those areas
