Question about Sunfire True Sub MK II Subwoofer
Sub doesnt do anything while plugged in ( Sunfire mk II)
The "on" light never comes on. It is plugged into the AC outlet, and then via monster cable, plugged into my reciever port on the rear of my onkyo reciever. doesnt play, doesnt do anything. I checked the fuse, it appears to be okay.
I did hear a hum from my other speakers but researched and found it was due to some field caused by the cable comming into the room and being near it. note that did not occur when my velodyne 12 inch sub was hooked up with the exact same set up successfully.
    Novelist:
  • 133 Answers
Some subwoofers can sense the signal on their input and will only start when there's enough signal for long enough time for them to turn on the amp.
Try seting the "subwoofer signal out" on your reciever a bit higher, see if it does the trick, if not, try it with some other source (e.g. an mp3 or CD/DVD player) plugged directly into the subwoofer. If it still doesn't work, there's some other problem with your sub (bad connection inside sub, sub amplifier problems, maybe there's another fuse for the speaker itself, try to check it out).
If it works well with an alternate signal source, the problem might be either in reciever or the signal cable that you use, but could also be something else.
good luck
3rq8 (Triarcuate)
Posted on Jul 15, 2009
Own a Sunfire True Sub MKII, light on but no bass, when volume on all the way it barely hits. Fuses appear to be ok.Circuit board looked ok I dint notice any blown caps or miscolored resistors. Help?
Start with the volume way down on the sub.
Connect the line out of a source you know is working with cables you know work to the inputs of the sub. Try left and right.
This will let you know if the problem is in the sub or the output you're trying to use.
Oct 05, 2015 | Sunfire True Sub MK II Subwoofer
Sunfire MK II Subwoofer hum. I have a Sunfire MK II subwoofer that hums when it is plugged in (it even hums when no signal is connected). I've tried multiple outlets on different circuits, but hum...
you have a ground loop issue you could purchase a ground loop isolator, jensen makes them for about 40 bucks.I have discovered that if you have cable tv, unplug the incoming cable in your cable box and see if hum disappears.
Nov 25, 2010 | Sunfire True Sub MK II Subwoofer
How to get rid of the hum
Check your cabling to make sure you dont have a ground fault. if you still have humming, buy a "groundless" adapter for your power plug (takes the ground away) and plug it back into the power outlet and I bet your humming will be gone
May 10, 2010 | Sunfire True Sub MK II Subwoofer
Needs repair - loud humming noises when turned on who are service agents in Melbourne australia
had the same problem, so I installed a radio shack ground loop isolator and fixed the problem, it has 2 rca plug inputs and 2 rca outputs, goes in-between the sub and the input cables of your system to the sub...that's if your using the rca inputs..
Aug 04, 2009 | Sunfire True Sub MK II Subwoofer
Blown Driver Sunfire MKII True Sub, looking for replacement woofer.
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=297-460&ctab=2#Tabs
Jul 02, 2009 | Sunfire True Sub MK II Subwoofer
Got power..but no sound
Your sub may have gone into protective shutdown to prevent failure as a result of "thurderous (sic) performance".
Mar 18, 2017 | Sunfire True Sub MK II Subwoofer
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
Sunfire True Sub MK II Subwoofer Logo
481 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Joseph Hoffmann
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
