Question about Kenmore 24032\24036 Top Load Washer
Kenmore Mod# 110.25842400 lid switch
Kenmore Series 80 Model #110.258424000 lid switch works only when inserting a pen or other object into slot. How can I replace lid switch or increase length of lid pin
  • 5,911 Answers
The following link gives you step-by-step instructions on how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Jul 15, 2009
My kenmore 80 series washer will not agitate. fills, drains, &spins great. coopler motor is good
inspect the lid to make sure it is closing properly. If the lid switch does not click into place correctly, your washing machine will not start. If the lid is simply bent, you should be able to bend it back into the correct shape to allow the switch to work. Otherwise, remove and replace the lid switch according to the manufacturer's instructions. move from wall, use a flash light and see if motor is running or it is a broken belt. check the lid switch first ! the easy way to check it is to open lid. hold down switch with a screw driver or simillar object. and see if it starts to agitate. if it does its the switch.
Oct 18, 2011 | Kenmore 24032\24036 Top Load Washer
Water is not draining after wash....Kenmore 80 series is what I have.
next time send the model number,open the lid and around the opening where you put the clothes in look on the back top wall of the opening,you'll see like 110. or something like that,i need the first three numbers and the eight numbers after the dot,if it's not draining the first thing i would check is the lid switch,open the lid around two inches and close it then open it and close it,if you don't hereit clicking you broke the lid switch,let me know what you find and send the model number and i'll tell you what part you need,also you can stick a screw driver or a pen in the hole on the top of washer and see if it will start to drain,let me know
Aug 26, 2010 | Kenmore Washing Machines
My kenmore 80 series washer started washing, the tub filled with water and now the tub is filled with water and won't empty or continue
Check to make sure the safety switch under the lid is being made. Use a popsicle stick or some other non conductive object to gently push down on the switch. When the switch engages it should start working. The switch is located in a small recessed notch under the lid of the machine.
Jun 15, 2010 | Washing Machines
Mod. 110.29852992 80 series will not pump out
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.29852992&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
It also has a troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips,pull the console forward and tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
May 12, 2010 | Kenmore Washing Machines
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Kenmore 80 series mod 110225842400 stopped working during cycle. Tub won't drain and will not agitate.
Hi, When the washer is in spin or wash cyles, do you here any motor noises? It sounds like the lid switch might be bad. Sometimes you can actually see if the lid switch is broke or not. Please let me know if The lid switch appears to be the problem or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 20172 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
705 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
