Question about Kitchen Appliances - Others
Problem with KitchenAid KUIA18PNLS0 Under-Counter 18-inch Ice Mak
Switch Position OFF - system is off, though Drain Pump will operate if water is in the drain reservoir (pour water into drain, melting ice, emptying of Water Reservoir, etc.).
Switch Position ON - Water Valve fills Water Reservoir (30 secs. or so, resulting in overflow into drain, as designed. Drain Pump kicks in (appears to turn off all other functions) and removes water (15 secs. or so), as designed. When completed, power is restored to system and Water Valve adds more water to Water Reservoir (already full, 30 secs.), resulting in overflow. Drain Pump kicks in (15 secs.). Cycles indefinitely - 30 minutes or more. Occasionally, there are deviations from this cycle. See Deviations (below).
Switch Position Clean - Compressor turns on, Water Pump turns on, and water is pumped across the Evaporator. The system appears to switch into a reverse/heat pump manner, where the Evaporator is heated and ultimately the fluids used to clean are also heated. This appears to be as designed and would (I think) contribute to a good cleaning process. Occasionally, the Water Valve adds water, which discharges some of the cleaning agent (nickle safe cleaner). Over time, most of the cleaning agent is replaced with water. While manual says the Cleaning Cycle last approximately 45 minutes, it appeared to run indefinitely until manually cancelled.
Deviations during Switch On cycle - always starts with Water Valve overflow and Drain Pump cycle for 20-30 minutes following an Switch Off to Switch On toggle. Have observed: Water pump and compressor turn on and the creation of ice sheet on Evaporator. Sometimes this is halted with a return the the Water Valve/Drain Pump cycle. Sometimes this results in a sheet of ice, which slides onto the Cutter Grid, as designed, but always returns to the Water Valve/Drain Pump cycle.
Inspection: Have inspected nearly all components and connection, observing no obvious faults. This includes PC Board, assembly switch, light switch, transformer, wire harness, etc., etc. All connections are clean, tight, and corrosion-free. PC Board shows no evidence of burn out resistors or components.
Overall, the appliance is clean and has been descaled manually and with appropriate metal-safe cleaner through cycle, though it has not been in operation for at least one-year.
Any suggestions or recommendations would be appreciated.
There is no solution. I have three kitchenaid ice makers and they do not work. The 18inch was under warranty. I had it serviced every friday until warranty ran out. I put an inline filter on the machine and it ran like a charm for three months, which is a first. It's out again! The two 15 inch same thing... inline filter and it worked for a month. Yes I have cleaned the machine over and over with appropriate products. It will turn on water fills but it appears as though the pump is not moving the water. Either way the machine worked correctly for two years only for the 15 inch and for the 18 inch one year.
Posted on Feb 25, 2011
Hoshizaki am-25ae. We have inherited a AM-25AE with the lodge we bought and it works just fine. We do want to give it a very good clean inside and disinfect the whole water 'way' to ensure the ice won
Cleaning Instructions:
Water System
1) Dilute approximately 5 fl. oz. (148 ml) of recommended cleaner Hoshizaki " Scale Away" or "Lime-A-Way" ( Economics Laboratory, Inc) with 1 gal. (3.8 lit) of water.
2) Remove all ice from the Evaporator and the storage bin. Note: To remove cubes on the evaporator, remove the front panel ( Lower), move the control switch on the control box to the "OFF" position and move it back to the "ICE" position after 2 minutes. The harvest cycle starts and the cubes will be removed from the evaporator plate.
3) Move the control switch to the "OFF" position. Close the water supply line shut-off valve.
4) Remove the water tank to drain the water. Refit the water tank in its correct position.
5) Slowly pour the cleaning solution into the water tank.
6) Move the control switch to the "WASH" position.
7) After circulating the cleaner solution for about 30 minutes, move the control switch to the "OFF" position.
8) Remove the water tank to drain the cleaning solution. Refit the water tank in its correct position.
9) Open the shut-off-valve.
10) Move the control switch to the "WASH" position to circulate clean water for about 5 minutes.
11) Move the control switch to the "OFF" position and immediately back to the "WASH" position to rinse water.
12) Repeat the above rinse procedure three more times to rinse thoroughly.
13) Dilute approximately 0.5 fl. oz. (14.8 ml) of 5.25% sodium hypochlorite (Chlorine bleach) with 1 gal. (3.8 lit) of water.
14) Move the control switch to the "OFF" position. Close the water supply line Shut-off-valve.
15) Remove the water tank to drain the water. Refit the water tank in its correct position.
16) Slowly pour the sanitizing solution into the water tank.
17) Move the control switch to the "WASH" position.
18) After circulating the sanitizing solution for about 15 minutes, move the control switch to the "OFF" position.
19) Remove the water tank to drain the sanitizing solution. Refit the water tank in its correct position.
20) Open the shut-off valve.
21) Move the control switch to the "WASH" position to circulate clean water for about 5 minutes.
22) Move the control switch to the (OFF) position and immediately back to the "WASH" position to rinse water.
23) Repeat the above rinse procedure two more times to rinse thoroughly.
24) Move the control switch to the "ICE" position, and start the automatic ice making process. Refit the front panel (LOWER) in its correct position. abut do not forget to wash and sanitize the ice bin.
Sep 01, 2014 | Kitchen Appliances - Others
GE WBVH6240 front load washer runs on 38 min. of the speed wash cycle then stops and door unlocks at 18 min. Tried to restart via the drain and rinse cycle at 18 min., the water pump comes on but no spin...
Hello, Welcome to FixYa.
The first thing I'd suggest is removing the filter in the pump you spoke of and insuring the pump is clear...there may be alot of water though so hopefully you're close to a drain or have some buckets/towels handy.
If that fails to resolve the problem it could be a plugged or faulty pressure switch. Have you run a system diagnostic yet ?
Here's how and the subsequent code meanings...in the event you don't know...
Let me know if any of this helps or perhaps you cannot read it, It is all included in the service manual I can send via email if you could use it.
Good luck.
Regards,
Macmarkus :)
May 06, 2011 | GE WBVH6240F Front Load Washer
Kitchenaid stand alone ice maker not producing ice. Water fills into the resevoir but do not see water flowing on to the ice pan. water drains from the tub fine when called for and fills back up. Was...
most likely the recirculating pump is jammed or has failed... ive been in service industry for 18 years and actually have a kitchen aid stainless steel ice machine myself.... if you get into unit and remove the resorvoir and white plastic shield around pump which is located on right side normally.. then there is 3 1/4 inch screws to remove from the pump and the water line usually attached on side of pump plate just unsnap... unplug the molex plug and pull out... you can check impellar for scaling and or build up turn with hand.. if you think you free it up clean real well and test with a power cord while out. you will have to rig something to the molex plug and plug into a 110 outlet and test... if it is bad get you a new one and replace.... this is a common problem ...good luck to you
Jan 08, 2011 | KitchenAid Kitchen Appliances - Others
Drain pump runs non-stop. Continues when dial is in Stop position. When disconnected for hours, drain pump starts immediately when power restored. In any wash cycle position, drain pump runs and cycle...
sounds like the flood switch has activated.
You will have to drag the dishwasher out from under the counter after turning off the power to it. Tilt to one side so that any water collected under it is expelled. This will free up the flood switch. Wait about 30 minutes and turn the power back on.
There could be a leak of some sorts from the door seal or hoses which is causing the water to collect.
Hope this solves the problem. It is unclear why none of the lights are lighting up to show a fault condition.
Nov 09, 2010 | Miele 23 in. Novotronic G841 Built-In...
KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Jul 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Stand Alone ice maker leak
Your model number must be plumbed to a external drain.
You may have to install a condensation pump to do this.
Mar 10, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Under counter ice maker water pickup problem
Most likely your plastic curtain is not keeping the water in the sump area. ( I'm assuming it makes round cubes)? Look under the sump for any dripping if its a pretty steady drip replace your water curtain and the holder that's with it.
If you have a cutting grid type ice machine this is all together different and I need to tell you separately about that.
Jan 01, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
KitchenAid Ice Machine doesn't freeze water to make ice. The water flows over the freezing plate, but no ice.
First check the switch and make sure it is not in the clean position.
Check for compressor operation. if the machine is in the clean position the compressor will not run and form ice.
May 31, 2008 | Refrigerators
Kitchen Appliances - Others Logo
512 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
